Class A Tube Headphone Amplifier Circuit Mosfet Hybrid
| Updated on August 3, 2019
Headphone Amplifier Circuit simply have a design or even the first single MOSFET as the design begins after two MOSFETs used and 6n6p ecc99 lamp Adding the lamp operating voltage 70 … 80V inter-addition for the MOSFETs 18 … 20v voltages required. The second box of the amplifier are also very well designed. Hybrid schemes belonging to the amp, PCB materials list.
hybrid-headphone-amplifier-class-a-interest-to-electronic-engineers
headphone-amplifier-ecc99-russian-power-triode-6n6p-class-a
lambali-kulaklik-anfisi-tube-amplifier
Source: republika.pl/audioton/index.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18060.zip
Publication date: 2011/12/04 Tags: ,
1 Comment “Class A Tube Headphone Amplifier Circuit Mosfet Hybrid
    Complete LPT CNC Project L298 L297 Motor Driver Circuit
    System previously shared CNC control circuit similar to the even circuit design assure the quality of and documentation to be complete this project better makes also L297 L298 motor driver board single sided pcb design made ​​LPT card single-sided PCBs different projects available in. CNC modules diagrams, pcb drawings, material lists and wiring diagrams are.
