TDA7294 Active Subwoofer Circuit TL494 Switchmode Power Supply
| Updated on August 21, 2023
I’m dealing with a lot of computer power supply circuit arrangement made ​​with EI33 transformer used almost all AT, ATX SMPS control IC TL494 psi resources found in
SMPS output voltage operated 2X30 watt amp 140 volt power circuit TDA7294 made ​​by 2 psi through bridge connections removed mono bass amp transformer windings distributed and repackaged information given in the circuit diagram
🙂 Very interesting design looks complicated, but most of the crowd 220v input filter, DC filter sections constitute a single pcb circuit with a small becomes a regular
TDA7294 Active Subwoofer Project
anfi-smps-kabin-icinde-150x150 anfili-smps-bass-Subwoofer--150x150 tl494-simetrik-smps-2x30-volt--150x150
active-subwoofer-140w-gdn-22-300-8-sw-schematic-2
A few months ago I started building a subwoofer, which originally had a reach 70W on the speaker STX GDN-25-100-4-SC. Of course, as thoughts on the design of my ambitions grew, grew up to 140W and change the speaker on the STX GDN-22-300-8-SW 🙂 The subwoofer is equipped with a bridge amplifier for the TDA7294. Heatsink surface within 1000cm ^ 2 is a little too big, but it was bought for pennies, so I do not damage 😉
The amplifier is powered pulse power supply. It is a converted ATX power supply, used is all part of the primary and the secondary part of the driver and made money. The inverter has an output voltage stabilization that is loose + /-34V, and a full load drops to + /-29V. Such a large voltage drop is caused by a very strong signal of the error amplifier compensation controller. With a weaker compensation, ie the strengthening of the voltage error amplifier row 100 .200 x, voltage drops under full load for a single millivolts 😉 But as rigid characteristics entail greater fluctuations in current, so I decided to soften it. The converter also has a thermal thermistor, resistor and comparator. I put a full diagram of the inverter:
source elektroda.pl
Publication date: 2009/07/26 Tags: , , ,
1 Comment “TDA7294 Active Subwoofer Circuit TL494 Switchmode Power Supply
    Simple metal detector circuit in walls for metals
    Siliconchip shared for free on the site where one of the projects sold stock fitters use a little more of a detector device is simple, inexpensive version can be called at short-range metal detector.
    In-wall cables are used to find metals known within the walls of electricity, water and so on. There are systems in place for any arrangements necessary to determine their
    LM358 opamp circuit and based on the popular 555 timer works with a 9 volt battery used for metal detection coil wire from 0.25mm to 20.5mm plastic turmoil over 400 to be wound round nails, etc. used as an indicator LEDs dim lights. metals such as bright lights with low metal content (copper cable, etc.). reportedly detected
    walls metal detector circui
