Character LCDs used in the custom-defined characters outside of the Standard Fonts. In this article; using a custom-defined Character parts and proper typing program code as displayed on the screen such as the following one line 2 line font name can be used. The only bad side to fit on the screen at the same time 4 characters. A simple clock application or a similar application in this way can be used in a design.
About this app using 16×2 character LCD Jalv2 language by defining the use of special characters and you’ll see how to use large fonts. First, we must establish the circuit in the figure below.
Half-time to try our code 16F628 and 16×2 Alphanumeric LCD is used. Make the appropriate connection type in the code you can try or you can write a program in another language.
Jalv2 of the project’s source codes and proteus isis simulation file:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22008.zip
Published: 2013/08/14 Tags: microchip projects, microcontroller projects
Proteus Ares 3D Model Archive Series 3
Previously a lot of proteus proteus 3D model objects sharing was made; Proteus Ares 3D Model library and a New 3D model files this time, shared a lot of great 3D model of ares proteus archive electronic component drawing most of the 3d model file has there a example of ares pcb (.lyt extension) let me tell you in advance if you have trouble viewing the model files are made with the pcb file if you want to keep the model files in a separate location “Proteus 3d Modeling”, review the descriptions in the article
Zeichen-LCD mit Jalv2 Große Schrift
Character-LCDs verwendet die benutzerdefinierte Zeichen außerhalb des Standard-Schriftarten. In diesem Artikel, und verwenden Sie eine benutzerdefinierte Zeichen-Teile und der korrekten Eingabe der Programm-code wie auf dem Bildschirm angezeigt, wie das folgende line 2 line-font-name verwendet werden kann. Die einzige schlechte Seite, um auf den Bildschirm passen gleichzeitig 4 Zeichen. Eine einfache Uhr-Anwendung oder eine ähnliche Anwendung, die in dieser Weise verwendet werden können in einem design.
