IR Protocol Analyzer Program
| Updated on August 3, 2019
ir Protocol Analyzer to use the sound card’s microphone input 1 x photo transistor connected to the controller, which uses the Protocol startbit, command, see the information on the program the address etc. information can also have graphic works export as the feature of “file” menu in the program installation without requiring the “samples” folder, you can examine the Protocol logs. Has source code for developers deplhi.
IR protocol analyzer is a universal application for automatic decoding dozens types of infrared remote control protocol packets. The application uses microphone input of a soundcard to capture infrared signal form a remote control. As a consequence, the hardware receiver is minimalistic and easy to build; just plug a phototransistor to input of your soundcard, that’s all hardware you need.
ir-protocol-analyzer-phototransistor-ir-hardware-receiver-analyzing-remote
Source: ostan.cz/IR_protocol_analyzer alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19610.zip
Publication date: 2012/08/29 Tags:
2 Comments “IR Protocol Analyzer Program
    DC to DC converter circuit 1400W SG3525
    1400w 12v DC to DC converter circuit dc voltage converter circuit as symmetrical +-70V dc is turning sg3525 SMPS PWM control IC is used on the floor. In practice, the output transformer used optionally divided into two parts to meet more precisely 1400w power single core can also be used if nüvebulun. Primary and secondary windings of the wire used in the parallel connection used to be very thick.
    Primary (which took part MOSFETs) 2 × 6 round wire secondary output section 5x1mm 6x1mm 2 × 24 round is hemmed in by a wire diagram, pcb winding outside the core have on the picture.
    IR-Protokoll-Analysator-Programm
    ir Protocol Analyzer zur Verwendung der Mikrofoneingang der Soundkarte 1 x Fototransistor an den Controller, der den Protocol startbit, Befehl verwendet, sehen Sie die Informationen auf dem Programm die Adresse usw. Informationen können auch grafische Arbeiten Export als die Funktion von “Datei Msgstr “Menü in der Programminstallation, ohne den Ordner” samples “zu benötigen, können Sie die Protokollprotokolle untersuchen. Hat Quellcode für Entwickler deplhi.
    IR-Protokoll-Analysator ist eine universelle Anwendung für die automatische Decodierung Dutzender Arten von Infrarot-Fernbedienung Protokoll-Pakete. Die Anwendung verwendet den Mikrofoneingang einer Soundkarte, um das Infrarotsignal einer Fernbedienung zu erfassen. Als Konsequenz ist der Hardware-Empfänger minimalistisch und einfach zu bauen; Schließen Sie einfach einen Fototransistor an den Eingang Ihrer Soundkarte an, das ist alles, was Sie brauchen.
