Increase Your Car’s Performance Battery Voltage Stabilizer Grounding
| Updated on March 3, 2025
Especially in old vehicles, electrical installation is a big problem, due to vehicle age, usage period etc. there are voltage problems. Especially in the chassis, oxidation, oiling, aging of high current cables etc. The Japanese have offered various products in terms of grounding. I decided to apply the system in my vehicle, the first part of this article
The most common and most used of these are; “HKS grounding kit” and “Pivot Raizin Voltage Stabilizer”
hks-grounding-kit-pivot-raizin-voltage-stabilizer-montage
Raizin Voltage Stabilizer consists of 5 capacitors, LED, display voltage indicator and fuses. Special capacitors are connected in parallel, totaling 21000uf special, while we say capacitor we know is actually better to say quality instead of special, low ESR. resistant to shocks etc.
Raizin Battery Voltage Stabilizer kit also comes with extra chassis cables. As seen in the diagram below, additional cables (between 8..12mm thick) are connected from the negative pole of the battery to the car main chassis, engine cylinder cover, distributor and alternator.
Note: Some users have stated that it is useful to make a chassis connection to the starter motor.
cable-connection-pivot-raizin-setup-hks-ground-connection
Benefits of Raizin Voltage Stabilizer Kit
Reduces or completely eliminates idle vibration.
Faster engine start in cold weather.
Increases starting torque.
Fuel savings can be 5% or more.
Increases the brightness of headlights.
Improves the quality of the car audio system.
Example of ignition coil changes
skop
Voltage change test Voltage change for battery negative terminal and other parts
voltage-change-test-pivot-raizin-voltage-stabilizer-eng
Pivot Raizin Circuit Diagram
pivot-raizin-voltage-stabilizer-schematic-circuit-diagram
Finally, it is debatable how effective the Raizin Voltage Stabilizer or balancing device is. I think the real work ends with the extra chassis because many components of the vehicle take the negative from the battery from the vehicle chassis, the assembly, connection areas get dirty over time, and the transmission weakens due to dust, oil, etc.
I will make and use a similar Raizin Voltage Stabilizer device, the original is no longer produced, there are fakes on the market. When it became popular, they made a much more advanced device.
pcb-pivot-raizin-voltage-stabilizer-pcb-board-layout-diy
clone-pivot-raizin-voltage-stabilizer-schematic-diy-3300uf
CAUTION You may damage your car with incorrect or wrong connections. Pay attention to the connections. If you connect the + – poles in reverse, there may be a big explosion.
Increase Your Car's Performance Battery Voltage Stabilizer Grounding
Publication date: 2025/03/03 Tags:
