Occasionally I use a simple method, many people do not know recently an ab dc motor driver asked what would be used to ask when I left or right engine to change the direction said that a circuit is not necessary to’ve told you many our simple Although it seems inform have benefits.
First, we will use the key tell you about happening in the market with the name known I do not know, I two-position switch or button my skin is open part are short-circuited turned off other parts of the short-circuited to change motor direction we can use for key six-legged in English “Toggle Switch” is mentioned as
6 `s the key and is bi-directional and independent two-key is the key end up when you remove the key the mid-leg with the other leg are short-circuited lowered the mid-leg with the other leg short-circuited ends in the middle when left no part shorted not (some of the key in the middle none) following better understand the situation with photos
Now with a simple cross-connect switch dc motor turned off by the direction we change. 1 and 4, 3 and 6 legs are combining with a cord in the same process we do this together 🙂 I came up with the numbering may not be in every key there is no maybe. Then we run the engine to the middle-end of the power supply + and – terminals are connected at
As you can see in the picture above with a very simple system dc motor + – changing the location of the poles are able to rotate in the direction we want.
Published: 2010/01/02 Tags: interesting projects electronics
LM35 Temperature Sensor CCS C PIC18F452 Application
I did this about 3-4 months ago, a friend of the circuit files universities, exams … etc. I can share new reasons :). With graphic LCD circuit development even though many of these circuits to implement any of them, unfortunately, I did not have enough material and time. In the days ahead I will make application development board thanks hopefully it’s quite comfortable. If you find the LCD touch panel and the appropriate graphics on these two elements to create small little applications and articles I think.
PIC18F452 LM35 Temperature Sensor Proteus
