Many component manufacturers such as STMicroelectronics of Mul products to promote their various cards are preparing 2Kv power 3-phase motor drive Node from these studies one .. Circuit of the best in fine detail all the information and coats scheme gerber files there.
IGBT 2 kV 3-phase motor drive circuit control STGIPS20K60 driver integrated with the provided especially current sensing, fan control, filters, etc. .. such departments in different projects can be useful or enlightened could, though in these chapters in the market, not op amp used but classic op amp is available in the net to Although the manufacturer typically using components in circuits produced the latest ..
Meanwhile STGIPS20K60 IGBT module afilli been very stylish way 🙂
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16166.zip
Published: 2011/09/13 Tags: motor control circuit, motor driver circuit
Professional Guitar Amplifier Circuit
The design is very good speaker guitar amplifier dc protection circuit 5 band equalizer amplifier amplifier parts on the floor of the pre has Irfp240 Irfp9240 MOSFETs used. Input amplifier voltage gain and control area +/-7five DB bandwidth can be set. According to the very high performance oscilloscope measurements. The author states that the guitar amplifier circuits has been tested, tested in the project all the files in the schema, the pcb.
