Speed ​​Indicator Circuits Tachometer Atmel atmega8
| Updated on July 4, 2023
Atmel ATmega series of projects have been realized with the speedometer and LCD display are the different indicators used circuits.
Display circuit used Used atmega8l-8P. Hex file and prepared by Proteus. Dns file there. The circuit has two different versions of LCD ATMega16 and used ATMEGA8515
atmega8l_display
atmega8515_lcd_speed
atmel_lcd
Speed ​​Indicator Circuits files:
Publication date: 2008/02/18 Tags: , ,
1 Comment “Speed ​​Indicator Circuits Tachometer Atmel atmega8
    EEPROM copier circuit Atmel AT90S2313
    In particular, a lot of people dealing with television repair business that would work with an EEPROM circuitry in copying a one-to-one can copy my eepromu.
    Copy circuit Atmel AT90S2313 built on a beautiful application PBC and. Hex. Thousand source files have the monitor television from various devices like 24xx series EEPROM using frequent failures of devices performing eprom files kpyalayıp backup can take a solid archives can create
    EPROM copier
