You can convert pictures in BMP format to picbasic pro pbp codes, if you want, you can convert the picture you selected from the Open section by pressing the “Convert Vert” button. GLiPIC provides an easy method of exporting images to the LCD as well as providing configurable code to your program.
It is a 600kb program that does not require installation, has detailed features, font selection can be made. It has settings such as com port, mcu, eeprom, and there are also ready-made shapes (brush style)
GLiPIC (Graphic Lcd interface to PIC) Utility. GLiPIC provides an easy method for exporting images to the LCD as well as providing configurable code to use in your program. Demonstrated in a prototype interface with a 128×64 display (LCD controller based on KS0108)
KS0108 LCD Examples
BMP to PicBasic Pro
GLiPIC provides an easy method of transferring images to the LCD as well as providing configurable code that can be pasted into your program Shown with a 128×64 display ( KS0108 based LCD controller) on a prototype interface
Above, the new GLiPIC super compact board. It measures a mere 1.9 x 2.5 inches! It houses a PIC 16F877, Max232, I2C eeprom along with an LM7805 power regulator.
I have some KS0108 beta code available for testing. The files include the Windows GLiPIC application, Windows BINHEX utility, PBP code for glipic, and a couple of alphanumeric sets. I will be posting the terminal applications shortly
Source: compsys1.com/workbench/Benchware/Glipic/glipic.html
Publication date: 2009/03/08 Tags: electronics software tools
PS2 Keyboard Keylogger Circuit Atmel AT89C2051
Atmel AT89C2051 circuit PS2 keyboard keylogger project installed on the PC connection cable is connected between the circuit is written after writing on AT24C512 EEPROM EEPROM is read by the program running on the PC
Keyboard Keylogger Project
