I do not know, but I know much about G Code; CNC machine with PCB drilling process used in the measure to be drilled where the coordinates of a file that some PCB drawing programs “export” menu has this option probably like I do not know much, but the “G Code Excellon” CNC jobs of those involved with to help business a free program ..
Excellon files will be converted to DIN G-code
Resizing and moving geometric data
Customize the number format
G00/g01-kommandos or drilling cycle
G79/G81 and production parameters or
Line numbers automatically be
Akkondesk creation tool definition files
Source: burger-web.com alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16155.zip
Published: 2011/09/12 Tags: electronics software tools
Electronics Lab Power Supply 0-30V 0-5A
Design an old but good quality op amp cmos and transistor consisting of an Electronic Laboratory for indispensable voltage current ayal power supply circuit output stage 5 pcs 2N3055 used to control the LM741 opamp and CD4013 is used power supply chart of the printed circuit board, layout, materials list. Elon a shared circuit in electronic journals
