24V Switch Mode Power Supply FSFR2100
| Updated on August 3, 2019
FSFR2100 Fairchild production of a new generation of very powerful SMPS control driver IC power MOSFET integrated in the complete 300 kHz operating frequency is being used to feed the lcd SMPS circuit televuzyon have but a very ideal for the application.
Switch Mode Power Supply FSFR2100 LCD TV
The evaluation kit for the FSFR2100. It should be used in conjunction with the FSFR2100 datasheet as well as Fairchild application note AN-4151 and technical support team. Please visit Fairchild’s website at www.fairchildsemi.com.
FSFR2100 is an integrated Pulse-Frequency-Modulation (PFM) controller and MOSFETs especially designed for Zero-Voltage-Switching (ZVS) resonant half-bridge converter topologies. Variable frequency control with 50% duty cycle for half-bridge resonant converter topology High efficiency through zero voltage switching (ZVS)
Internal SuperFET®s with fast recovery type body diode (trr=120ns) Fixed dead time (350ns) Up to 300kHz operating frequency Pulse skipping for frequency limit (programmable) at light-load condition Simple remote ON/OFF control Various Protection functions: Over-Voltage Protection (OVP), Overload Protection (OLP), Over-Current Protection (OCP), Abnormal Over-Current Protection (AOCP), Internal Thermal Shutdown (TSD)
fsfr2100-lcd-tv-power-supply
fsfr2100-lcd-tv-power-supply-pcb-300khz
fsfr2100-smps-schematic-circuit-24v-8a-power
smps circuit files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19231.zip
Publication date: 2012/07/13 Tags: , , ,
2 Comments “24V Switch Mode Power Supply FSFR2100
    Arm Sumo Robot Project STM32F4
    Discovery ST Microelectronics ARM development STM32F4 production, based on experiments card to mini-water robot project that makes working with ARM beginners a good example for people TB6612FNG used for dc motor drive is used as a sensor Sharp GPY0D340K ..
    Schaltnetzteil 24V FSFR2100
    Schaltnetzteil FSFR2100 Fairchild Produktion einer neuen Generation von sehr leistungsfähigen SMPS-Steuertreiber IC Leistungs-MOSFET integriert in die komplette 300 kHz Betriebsfrequenz wird verwendet, um die lcd SMPS-Schaltung Televuzyon haben aber eine sehr ideale für die Anwendung.
    Schaltnetzteil FSFR2100 LCD TV
    Das Evaluierungskit für den FSFR2100. Es sollte in Verbindung mit dem FSFR2100-Datenblatt sowie dem Fairchild-Anwendungshinweis AN-4151 und dem technischen Support-Team verwendet werden. Bitte besuchen Sie die Fairchild-Website unter http://www.fairchildsemi.com.
    FSFR2100 ist ein integrierter Puls-Frequenz-Modulations- (PFM) Controller und MOSFETs, die speziell für Zero-Voltage-Switching (ZVS) resonante Halbbrücken-Wandlertopologien entwickelt wurden. Variable Frequenzregelung mit 50% Einschaltdauer für Halbbrücken-Wandler-Topologie Hoher Wirkungsgrad durch Nullspannungsschaltung (ZVS)
