Frequency Adjustable Bass Crossover Circuit
| Updated on July 26, 2024
The adjustable frequency Bass Crossover circuit is based on two opamps (tl071 tl072) integrated circuits, the operating voltage is symmetrical +15v -15v, there are two pots for gain and frequency settings, the frequency range is 10…60hz.
Since the circuit consumes low power, it can be operated with zener regulated or 78L15, 79L15 regulated power supply circuits.
The adjustable Bass filter circuit only has a PCB drawing and layout plan, there is no circuit diagram
10hz-60hz-sub-bass-filter-opamp-devre-subwoofer
aothor: tamircihasan Adjustable Subwoofer Crossover circuit pcb files :
Publication date: 2010/07/10 Tags:
1 Comment “Frequency Adjustable Bass Crossover Circuit
