“ST Lighting Designer Design your Fluorescent Tubes and CFLs Electronic Ballast for” ballast design program quite stylish and advanced PFC, etc. dimmer. There is also a lot of features “Inductor desinger” tool can be used in different applications.
Ballast design program on your computer to work for Microsoft. NET Framework version 2.0 or higher version must be installed
Several solutions are implemented: the user has just to specify the desired high-level requirements to obtain a full set of information to realize his own e-ballast!
Just three steps:
Specify the high-level requirements: mains range: European, American or Wide, lamp & ignition type, additional design options: PFC, dimming Select and Execute the preferred Solution: fixed or variable frequency based on our IC L6585, L6574, L6569, L6562 discrete solution based on STx724, STx83003, STx93003.
Get your Design and refine it to better meet your needs:
bill of materials,
fully annotated schematic,
lamp circuit working point, steady state simulation,
involved devices datasheet, application notes,
Sample video ballast design;
Download ballast design program:
Publication date: 2011/05/11 Tags: electronics software tools
Non-isolated Power Supply ViPer12A ViPer22A Desinger
“Vıper12 the vıper22 non-isolated power supply desinger” ST Microelectronics firm VIPer from the series viper12 viper22 integrated prepare for the non-insulated SMPS power supply design program especially white LEDs, power LEDs to run the various circuits can be designed or over-current uninteresting to any circuit feeds used in the core of the transformer coil is used instead of the construction will be a little easier.
