Universal Programmer works through the RS232 serial port of the computer. Programs are integrated as: Pic12 Microchip, Atmel AVR PIC16 series, AT89 SPI serial EEPROM 25xxx, 16 8-bit I2C EEPROM, 24XXX, at17xxx, 16 – 8-bit Micro Wire EEPROM 93xxx
Universal Programmer PonyProg and ıcpog able to work with the program. With a single control module programming is done via the card and all modules and motherboard pcb files have.
Programming in dealing with business people and especially ideal for use in technical service and not more than the cost of a circuit programmable EEPROM that kind of repair work to be plenty of things done with a single circuit provides
Source: Universal Programmer Universal Programmer circuit files alternative link:
Publication date: 2010/10/28 Tags: programmer circuit
3W Amplifier Circuit Battery Powered Stereo TDA7056AB
TDA7056 3W mono channel output allows a single integrated circuit used in two pieces. 3 … 18V DC supply voltj application has been run by 3 AA batteries.
TDA7056 3Watt BTL audio amplifier
