24V 500W motor driver circuit with a small electric car prepared for the circuit in the control TL494 PWM IC is used at the exit 4 irf2807 MOSFETs are driven further feedback there VFB guess “voltage” feed back means control solid supply 12V MOSFETs on the floor of the 24v is used 24v over the 12v being regulated supply provided below or in the wiring diagram in the middle end of the series connection of two batteries can be used as
Source: wara.com/article-682.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18253.zip
Published: 2012/01/03 Tags: motor control circuit, motor driver circuit, pwm circuits, tl494 circuit
All-in-One Microcontroller Experiment PCB
A very well designed specifically for microcontroller projects useful test card can be used in many different kılıflarda integrated standard input output ports that can be used for a long period of time, a plaque is used in high quality card also can be used in large, integrated part of universal tqfp. Finally, there is available an optional printed circuit board according to the double-layer 2
