While engaged in electric power cut-off when charging circuits have two pieces one 14.4v battery charger is not charging current to 500mA of charge vıltaj 4AH, suitable for 7AH battery. Other circuits are also doing the same job but li ion or lithium-polymer batteries designed to charge LiPo 4.2V or 8.4V charge voltage can be adjusted.
Circuit layout of the printed circuit sizes too small would be easy, especially pcb design of the circuit to charge the battery so kçük have fit into the direct SMPS adapter. PCB drawings and diagrams of circuits in addition to the source image format has the sprint pcb layout drawings and spline drawing diagrams in the 7’s
Source: mazeto.net/index.php/topic,6621.msg39177.html
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18480.zip
Publication date: 2012/01/30 Tags: battery charger circuit, power electronic projects
600ma Current Limiting Circuit 12V 5V IRF9530
The current limiting circuit shown in the diagram , especially as the drive power LED driver , this circuit can be used … Easy to use and inexpensive , keeping a constant level of output current regulator prevents damage . When a problem occurs on the transistor T1 circuit on the power consumption would be approximately equal to the input voltage . According to the circuit diagram of feedback resistor R4 to protect the transistor T1 with an additional current limiting circuit which is used.
Während der Abschaltung der Stromversorgung, wenn die Ladeschaltungen zwei Teile haben, lädt ein 14,4-V-Batterieladegerät den Strom nicht auf 500 mA, passend für eine 7-Ah-Batterie. Andere Schaltkreise erledigen den gleichen Job, aber Li-Ion- oder Lithium-Polymer-Akkus, die zum Laden der Ladespannung von LiPo 4,2 V oder 8,4 V ausgelegt sind, können eingestellt werden.
Schaltungslayout der gedruckten Schaltung zu klein wäre einfach, vor allem PCB-Design der Schaltung, um den Akku zu laden, so dass kçük in den direkten SMPS-Adapter passen. PCB-Zeichnungen und Schaltpläne zusätzlich zum Quellbildformat enthalten die Sprint-PCB-Layoutzeichnungen und Spline-Zeichnungsdiagramme in den 7ern
