the PIC12F629 on a microcontroller based electronic dice. electronic DICE with 14 LEDs dual membranes prepared for application software mikroc used to give random results when a button is pressed for 3 seconds if not used within 15 seconds after it goes to sleep mode normal operation of the circuit of the button continues. Electronic DICE circuit PCB Sprint layout prepared with ISIS simulation software source code that belong to the file and drawing.
Electronic Dice circuit
Electronic Dice Micro C Software
#define Butt GPIO.F3 #define On 0 // button on - GP3=0 void main() { unsigned char LED1, LED2, i, Timer = 0, Time_off = 0; TRISIO = 0; GPIO = 0; INTCON = (1<<GPIE); // IOC=0b00001000; // enable int. on change GP3 T1CON = 1 ; // TMR1-on, 1/65535 CMCON = 7 ; while(1) { if (PIR1.TMR1IF == 1) { PIR1.TMR1IF = 0; Time_off++ ; // increment off-timer to 1 at each 65ms } if (Butt == On) { Time_off = 0; // clear off-timer LED1 = (TMR1L%6)+1; // LED2 = (TMR1H%6)+1; // rand. led1 and led2 for (i=0; i<150; i++) // indication 150*20ms = 3 sec. { GPIO = (1<<4)|LED1; Delay_ms(10); GPIO = (1<<5)|LED2; Delay_ms(10); } GPIO = 0; } else { if (Time_off > 250) { // to sleep in 15s Time_off = 0; INTCON.GPIF=0; GPIO = 0; asm sleep; } } } }
Electronic Dice schematic
source: cxem.net/mc/mc352.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25433.zip
Publication date: 2016/04/22 Tags: microchip projects, microcontroller projects
Microwave Oven Transformer Made with electro magnets
If you want to make a simple but powerful electromagnet, micro-wave oven transformer and the transformer is cut off with a grinding machine of Palm’s primarily some sufficient labor is subtracted from the primary voltage to the secondary coil of hair after it is given
handmade electro magnets
Elektronischer Würfel Schaltplan Mit PIC12F629
der PIC12F629 auf einem mikrocontroller basierten elektronischen Würfel. elektronischer WÜRFEL mit 14 LEDs, dual-Membranen bereit für die Anwendung der software mikroc verwendet, um zufällige Ergebnisse, wenn Sie eine Taste für 3 Sekunden, wenn nicht innerhalb von 15 Sekunden nach geht es in den Schlaf-Modus Normalbetrieb der Schaltung der Schaltfläche weiter. Elektronischer WÜRFEL-Stromkreis Leiterplatte Sprint-layout vorbereitet mit ISIS-simulation, software-Quellcodes, gehören Sie zu der Datei und Zeichnung.
