Electronic Calculation Program For Radio Amateurs
| Updated on August 4, 2019
500kb size calculation is very useful and handy program that can do a lot by electronic
Antenna ERP calculations.
Debilitating calculations.
Audio filter design.
Coiled accounts.
Decibel calculations.
Great-Circle map and the calculator.
HF Filter Calculation.
Antenna HF Calculation.
Op-Amp Calculation.
Determine QRA (rear) / Longitude Latitude.
Radio Horizon account.
Satellite Orbit Calculation.
Timers.
The Calculation Of The Zener Diode.
Resonance and bandwidth.
Metric and other conversions.
buyuk-cemberler-harita-hesap-makinesi-great-circles-map-calculator
anten-erp-hesaplamalari-antenna-erp-calculations
anten-erp-hesaplamalari-uydu-yorunge-zamanlayicilar
desibel-hesaplamalari-decibel-calculations
hf-anten-tuzaklar-hf-antenna-traps
metrik-ve-diger-donusumleri-metric-and-other-conversions
rezonans-ve-bant-genisligi-resonance-and-bandwidth
ses-filtre-tasarimi-audio-filter-design
zayiflatici-hesaplamalari-attenuator-calculations
Electronic calculation program does not require installation and it’s free. In addition to the program .CHM help file, but a little different 🙂 this is from the Help file in the program you can do all calculations
555-timer-calculator-555-zamanlayici-hesaplayici
Note: .the CHM file when you open “navigation to the webpage was canceled” error if it appears .right click on the CHM file’s “properties” in the window that opens, click on “unblock” button click on
source: vwlowen.co.uk alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25451.zip
Publication date: 2016/04/22 Tags:
2 Comments “Electronic Calculation Program For Radio Amateurs
    Elektronischen Berechnungs-Programm Für Funkamateure
    500kb Größe Berechnung ist sehr nützliches und praktisches Programm, das kann eine Menge von elektronischen
    Antenne ERP-Berechnungen.
    Schwächende Berechnungen.
    Audio-filter-design.
    Coiled-Konten.
    Dezibel-Berechnungen.
    Great-Circle-Karte, und der Rechner.
    HF-Filter-Berechnung.
    Antenne HF-Berechnung.
    Op-Amp-Berechnung.
    Bestimmen QRA (hinten) / Längengrad Breitengrad.
    Radio Horizon-Konto.
    Satelliten-Orbit-Berechnung.
    Timer.
    Die Berechnung Des Zener-Diode.
    Die Resonanz und der Bandbreite.
    Metrik und anderen Konvertierungen.
