Workshop also especially when trying screwdriver is magnetized, magnetized to be my job very olaylaştırıy I’m sure a lot of people in the same thoughts as me are but sometimes in different jobs that magnetize magnetizing event my work can make it difficult in general collet, tweezers work I would have no problem …
I screwdriver to magnetize always in the corners standing speaker magnet I use the screwdriver magnetization decreases, the speakers took the business to continue but magnetized De-magnetizing device would be more portable .. device made extremely simple very little material is used 1pc 1n4007 diode, coil and two-position switch writer 230v for use with coil windings of the motor has been running in this engine are from the laminator
No direct AC mains voltage to the coil when the key is making the process de-magnetized change the location of 1n4007 DC when given half a contemplative process is not magnetized
Source: http://www.elteh.net/projekti/magnetizator-demagnetizator.html
Published: 2012/06/12 Tags: interesting projects electronics
Winamp Remote Circuit Bluetooth AT90USB1287 Nokia LCD LMX9838
A very detailed report of a project is already included in the schema, the author of the thesis, the eagle pcb source code etc. everything. The circuit used the main parts AT90USB1287 LMX9838 (Bluetooth module) W681310 (PCM codec IC) Indicator is being used in hardware resources, as well as the Nokia LCD for C/C++ codes with the Winamp Plugin and other program files are also useful for different projects.
