DIY Orthopedic Knee Chair
| Updated on July 3, 2020
It can be thought that sitting on the knee chair, does not look comfortable, but it is a very useful design especially for those who spend a lot of time at the computer. The parts can be made by hand, but it is much better with CNC. When sitting on a computer tongs for a long time, burning and pain in the neck begins. I am thinking of doing it ..
As seen below, the Orthopedic Knee Chair is not useless and the orthopedic knee chair, according to the manufacturers, allows you to maintain your posture while working at the table, reducing body load.
What is the advantage of the Knee Chair? As you can see in the picture below, everything is in the middle, the larger the angle of the seat, the more even a person keeps his back. It is connected with the center of gravity of the spine, because when sitting on an inclined surface, a person keeps his back involuntarily straight, because it is more comfortable, you can not hump even if you want.
diz-sandalyesi-oturma-performansi
Knee Chair Cutting Plan
drawing-plan-orthopedic-knee-chair-diz-sandalyesi-cizimi-120x120
Knee Chair make Notes
Beech tree is getting more solid. Drilling process The holes are drilled on both sides using a jig. The eye decision can be pierced, but it will be difficult to grab the angle from both sides very carefully, try to fix it to the right angle as much as possible.
It is better to make a level of thick plywood adjustment. Use 20mm or glue a few thinner pieces of plywood that are not thick.
ortopedik-sandalye-yapimi-1
ortopedik-sandalye-yapimi-2
ortopedik-sandalye-yapimi-3
Updates; Thicker sponges and reinforcement
diz-sandalyesi-mentese-sunger-modifiye
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-27189a.zip
Publication date: 2020/07/03 Tags:
