DIY Layout Creator for Hobbyists and Electronics Enthusiasts
| Updated on March 3, 2025
DIY Layout Creator (DIYLC) is a special software designed for hobbyists and electronics enthusiasts to create circuit layouts on breadboards, perforated boards, PCBs and point-to-point wiring. It provides an intuitive, drag-and-drop interface to place components, arrange connections and visualize circuit designs before assembly.
It allows users to design layouts with precision and clarity with its built-in component library and customization options. The software is especially useful for designing, analyzing and debugging guitar wiring diagrams, and helping musicians and makers plan and troubleshoot custom wiring configurations for pickups, switches and controls. Its versatility makes it an ideal solution for DIY electronics projects, prototyping and documentation.
An electronic drawing program that I knew from a long time ago, v4.40 has improved a lot compared to v1.8. Circuit diagrams can be drawn with the schematic symbol library. It is easier to use than others because it is a program that has been supported and developed by hobby electronics and musicians since the beginning.
The program can be used in many drawing works, not just electronics, its library is large and updated. In addition, SVG and other image files can be transferred to the drawing area. The DIY Layout Creator program has win., mac., arm, portable versions, as well as source codes.
diy-layout-creator-diylc-is-a-specialized-software-tool-designed-hobbyists-electronics
diagram-create-circuit-layouts-on-stripboard-perfboard-pcb-and-point-to-point-wiring
makes-ideal-solution-diy-electronics-projects-prototyping-documentation
Source: github.com/bancika/diy-layout-creator/releases
Publication date: 2025/03/03 Tags:
