For the circuit; It is called “Universal power control”. A circuit that reduces the brightness and therefore the power consumption of the energy saving lamp as a night lamp.
It is not recommended to use simple dimmer circuits to change the brightness of these lamps. In the electronic ballast circuits used in energy saving lamps, there is a system that works with regulators at the output after the bridge.
You can connect the conductor motors, soldering irons, lamps of any voltage, energy saving lamps, soldering irons up to 150 watts 220V.
Dimmer Circuit with Mosfet for Energy-Saving Lamps
Publication date: 2024/12/17 Tags: power electronic projects
