All the details of the project, the calculations of various information (in English) are also prepared with pic c language source code through software to have. Project uygulanmasa a very useful resource in current sensing, PWM control, the driver floors etc. can be useful in different projects.
SWITCH MODE POWER SUPPLY PROJECT FOR PRODUCING HALF WAVE SINE OUTPUT
In this thesis; analysis, design and implementation of a DC-DC converter with active clamp forward topology is presented. The main objective of this thesis is generating a rectified sinusoidal voltage at the output of the converter. This is accomplished by changing the reference signal of the converter. The converter output is applied to an inverter circuit in order to obtain sinusoidal waveform.
The zero crossing points of the converter is detected and the inverter drive signals are generated in order to obtain sinusoidal waveform from the output of the converter. Next, the operation of the DC-DC converter and sinusoidal output inverter coupled performance is investigated with resistive and inductive loads to find out how the proposed topology performs.
The design is implemented with an experimental set-up and steady state and dynamic performance of the designed power supply is tested. Finally an evaluation of how better performance can be obtained from this kind of arrangement to obtain a sinusoidal output inverted is thoroughly discussed.
author: İBRAHİM KAYA Source: goo.gl/e0x0
Publication date: 2010/08/28 Tags: dc dc converter circuit, microchip projects, microcontroller projects
IR2153 SMPS Circuit Project 2x50v Switch Mode Power Supply Test TDA7294
This is a bit confusing to distribute sort myself 🙂 small but great works to come to a new SMPS circuit with ir2153 did.
If you remember aha SMPS with ir2153 work I had before, “IR2153 and ATX SMPS Transformer with Symmetrical Output Voltage”
System did not benefit from the same PC power supply transformer, but this time I used a single drive circuit 2 circuit set up rough drafts I’ve tested the circuit was very simple output, input filter quite well although insufficient results
