There is a very advanced pic trial, test, project development circuit that I saw on hanf-elektrotechnik.de site, there are many functions, all resources are shared, there is also a test program (PIC_Board_Test.c) prepared in c language for you to test the circuit, the best part is the assembly section for the bredbord on the pcb. There is a volt supply voltage regulation with 7805 in the pic development circuit. You can run it with a dc 12v or 9v adapter.
Features
40-pin socket for PIC18F442/452 or PIC18F448/458 or PIC18F4550
28-pin socket for PIC18F242/252 or PIC18F248/258
All ports (female) accessible via headers.
Peripherals can be unlocked with DIL switches
two different LCD connectors
4×7 segment display (multiplexed with IC HEF4511)
2 x 8 LEDs
1 potentiometer for analog simulation
Reset module with 1 reset button
4 buttons
I2C for 24C04 or similar
2 x RS232 with 1 x SUB-D socket (2nd in pin array)
640 hole breadboard
ICSP and ICD connection
Internal Rectifier, regulator
Dimensions: 190mm x 140mm
picmicro development board
Publication date: 2009/05/10 Tags: avr development board, pic development board
RTL8019 ISA Web Server Circuit ATmega32 Relay Control Camera Connection
Very detailed and complicated project all of the resources to be shared for different applications feyza can give example might now mikrocontroller.co my site ATmega32 web server project shared resources of the project the ulrichradig. (previously it was mentioned, was shared) ISA ethernet card and atmel access control systems card
This web server card that will work with a module (I2C interface) mum-elektrotechnik. on the site shared module PCF8574 integrated on the board via web 8 relays can be controlled on-board LEDs situation is observed and the camera connection can be made with this module servo motor control could be made also mentioned all source code shared
ATmega32 Atmel Web Server
