GSM Sim Card Programmer Circuit
| Updated on July 27, 2024
GSM sim card sim card programmer with additional adapter cards are used in many micro controller programming, the program used to support PONY PROG
Olasa for use in circuit programmable integrated SIM cards are used in different cihazlarda will be very useful, especially in technical services of a programmer circuit
GSM Sim Programmer Supported chips
I2C Bus E-EPROM: 24C01 – 24C512
Siemens E-EPROM: SDE2516, SDE2526, SDA2546, SDA2586, SDA3546, SDA3586, SDE 2506
I2C Bus E-EPROM: 24C325 a 24C645
Atmel I2C E-EPROM: AT17C65, AT17C128, AT17C256, AT17C512, AT17C010
Atmel AVR ATmega : AT90S1200, AT90S2313, AT90S2323, AT90S2323, AT90S4433, AT90S2343, AT90S4414, AT90S4434, AT90S8515, AT90S8535 Flash micro ATmega603, ATmega103, ATmega161, ATmega163 ATtiny ATtiny12, ATtiny15
Atmel x51 ISP : AT89S8252 a AT89S53
Microwire E-EPROM: 93C06, 93C46, 93C56, 93C66, 93C76, 93C86 (C a LC)
Microchip PIC: PIC16C84/16F84 , 16F873/874/876/877, 12C508/509
SPI EEPROM: 25010, 25020, 25040, 25080, 25160, 25320, 25640, 25128, 25256
Source: http://www.siemensmania.cz/content.php?id=240 Sim Card Programmer circuit files Alternative link:
Publication date: 2010/08/04 Tags:
1 Comment “GSM Sim Card Programmer Circuit
    Images and text on the wheel LED display Bicycle wheels
    Wheel LED display went through an upgrade. A new version, which is able to portray the images as well as text on both sides of a bicycle wheel. The old version the display portrays only unilaterally. The article described the win application for uploading images to the LED display wheeled. The application is, of course, freely distributable-freeware.
    Many of us in the air writing project know the one in the air, so the project had on this project so the difference of the circuit bicycle wheels used in and work the beauty of writing or shape of the circuit with its own programs can install illustrated instruction manual and PCBs have drawings. PIC16F628 circuit based on MAX232 used for serial communications post.
    LED Bicycle
