You can also use your CNC project running from the computer’s LPT port interface control card to the 74HC14 integrated circuit uln2803 are based on the opto-isolation provided by pc817
I decided to design your own master plate for CNC applications but not only π (it is also used as a programmer for ATmega microcontrollers, as well as an early tester of simple programs control data output LPT port written in C + +)
CNC control interface board
There are 4 signal LEDs in the system, two of which give information about the presence of voltage 5 (LED1) and 12V (LED4). The next two indicate that relay 1 (LED2) and 2 (LED3) are working.
EXPLANATION OF BEGINNINGS:
β JP1-JP9;JP10,11,15,13,12; JP14,JP16,JP17 β outputs /LPT inputs respectively
β JP10; JP11 β 2x6GND designed for outputs from LPT port
β JP20 β ULN inputs (pins 1 and 2 control relay 1 and 2 respectively, while the other six inputs can be used any way)
β JP21 β ULN outputs
β JP12 β voltage connector 4x + 5V (eg to power controllers)
β JP12 β additional connector 4x GND (eg for powering controllers)
β X1 β 12V power input
β X2 β relay 2 connector
β X3 β relay 1 connector
CNC interface board circuit schematic etc. files:
Εifre-Pass: 320volt.com
Published: 2010/02/16 Tags: motor control circuit, motor driver circuit
TDA1514 2X50Watt High Performance HiFi Amplifier Circuit
TDA1514 alone can provide 50 watts of power supply voltage and a maximum of + – 30 volts mute / stantby temperature protection, overcurrent protection feature. Amp circuit with a few passive components can
