The Volkswagen RCD300 tape was in safe 2 mode. To learn the password, 95640 eeprom had to be read and the RCD300 password had to be obtained via the PC program, it took some effort, but I took the password and started the tape. CH341A EEprom Flash Programmer was used to read 95640 eeprom on RCD300 main board. CH341A device’s software (CH341A-programmer) has no support for 95xxx eeproms. I solved this problem with different program.
I said let’s try it with the SMD Soic cable clip that comes next to the CH341A module. By the way, use cream flux in this type of work, the dismantling process is very fast.
I used As Programmer, 95640 eeprom was read without any problem, and when I searched, I learned that the new version of the program was shared with the name of Neo programmer. With this program, CH341 exceeds the programmer limits, it can be programmed in many eeprom, flash as well as integrateds such as Atmel series Nuvoton. It also has USBasp programmer support. Details are in the video…
CH341A RCD300 Code and Details
CH341A programmer ZIF 5 Volt Modification
The “black pcb” version of the CH341A programmer also has a 3.3 volt voltage regulator to reduce the 5 volts from the USB socket. The VCC voltage of the ZIF socket is 3.3 volts.
When the 28 VCC pin of the CH341A IC is separated from the board and connected to the output of the AMS1117-3.3 regulator IC (SOT-223 middle leg 3.3V output) with a cable, when you short-circuit the 3.3.v – 5v header output, the ZIF becomes 5 volts in the socket, and 3.3 volts in the open circuit. ..
In other words, short-circuiting the input and output of the AMS1117-3.3 regulator is not a very healthy method, but it works. In addition, on the Neo programmer, which voltage you will choose according to the IC you have chosen is shown at the bottom. In addition, information is given about whether to use a ZIF socket connection or an adapter.
Note: I programmed the 95640 eeprom with CH341A. If you don’t need it, don’t risk it. CH341A can break when removing pin 28. Be careful. Also, for the CH341A 5V modification you see in the pictures below, there is a work done by cutting the 5V line on the PCB without interfering with the IC. (I didn’t try)
NEO PROGRAMMER Supported ICs (29/09/2021)
ENE:
KB9012*; KB9016*; KB901x*; KB902x*; KB9022*
SPI DATA Flash 45
ADESTO:
AT45DB011B_page264*; AT45DB021B_page264*; AT45DB041B_page264*; AT45DB081B_page264*
AT45DB161B_page528*; AT45DB321B_page528*; AT45DB642_page1056*; AT45DB011D_page256*
AT45DB021D_page256*; AT45DB041D_page256*; AT45DB081D_page256*; AT45DB161D_page512*
AT45DB321D_page512*; AT45DB322F_page256*; AT45DB641E_page256*; AT45DB642D_page1024*
AT45DB011D_page264*; AT45DB021D_page264*; AT45DB041D_page264*; AT45DB081D_page264*
AT45DB161D_page528*; AT45DB321D_page528*; AT45DB322F_page264*; AT45DB641E_page264*
AT45DB642D_page1056*; AT45DB1282_page1056*; AT25PE20_page256; AT25PE40_page256
AT25PE80_page256; AT25PE16_page512; AT25PE20_page264; AT25PE40_page264
AT25PE80_page264; AT25PE16_page528
SPI Flash NAND***
ATO:
ATO25D1GA
ETRON:
EM73C044VCF; EM73D044VCL; EM78D044VCM[1.8V]*; EM73E044VCB (Experimental)
ESMT:
F50L1G41LB; F50D1G41LB[1.8V]*; F50L2G41LB (2x1Gb Dies); F50D2G41LB[1.8V] (2x1Gb Dies)*
F50L2G41XA; F50D2G41XA[1.8V]*
FMSH:
FM25S01; FM25S01A; FM25G01B; FM25G02; FM25G02B; FM25G02C; FM25LG01B[1.8V]*
FM25LG02B[1.8V]*
GIGADEVICE:
GD5F1GQ4UAY; GD5F2GQ4UAY; GD5F1GQ4UExxH; GD5F1GQ4RExxH[1.8V]*; GD5F1GQ4UExxG
GD5F2GQ4RBxx[1.8V]*; GD5F1GQ4RExxG[1.8V]*; GD5F1GQ4UFxxG; GD5F2GQ4UFxxG
GD5F1GQ4RFxxG[1.8V]*; GD5F2GQ4RFxxG[1.8V]*
ISSI:
IS37SML01G1
MACRONIX:
MX35LF1GE4AB; MX35LF2GE4AB; MX35LF2G14AC; MX35LF2GE4AD; MX35LF1G24AD
MX35LF2G24AD; MX35UF1G14AC[1.8V]*; MX35UF2G14AC[1.8V]*; MX35UF1GE4AC[1.8V]*
MX35UF2GE4AC[1.8V]*
MICRON:
MT29F1G01AAADD; MT29F1G01ABAFDSF; MT29F2G01AAAED; MT29F2G01ABAGDSF
MT29F1G01ABBFDxx[1.8V]*; MT29F2G01ABB[1.8V]*
PARAGON:
PN26G01AW[1.8V]*; PN26G01A; PN26G02A
Toshiba_KIOXIA:
TC58CVG0S3HxxG; TC58CVG1S3HxxG; TC58CYG0S3HxxG[1.8V]*; TC58CYG1S3HxxG[1.8V]*
TC58CVG0S3HxxJ; TC58CVG1S3HxxJ; TC58CYG0S3HxxJ[1.8V]*; TC58CYG1S3HxxJ[1.8V]*
WINBOND:
W25N512GV; W25N512GW[1.8V]*; W25N01GV; W25N01GW[1.8V]*; W25N02JW[1.8V]*
W25M02GV (2x1Gb Dies); W25M02GW[1.8V] (2x1Gb Dies)*
Zetta:
ZD35Q1GA; ZD35M1GA[1.8V]*; ZD35Q2GA; ZD35M2GA[1.8V]*
SPI Serial NOR + Serial NAND ********************
WINBOND:
W25M161AV (SpiStack NOR 16Mb + NAND 1Gb); W25M321AV (SpiStack NOR 32Mb + NAND 1Gb)
W25M641AV (SpiStack NOR 64Mb + NAND 1Gb); W25M121AV (SpiStack NOR 128Mb + NAND 1Gb)
SPI Flash NOR****
ACE:
ACE25C512; ACE25C100; ACE25C200; ACE25C400G; ACE25C800G; ACE25C160G
ACE25C320G; ACE25A128G[1.8V]*
ADESTO:
AT25DN256; AT25DF256; AT25F512B; AT25DN512C; AT25DF512C; AT25XE512C
AT25DN011; AT25DF011; AT25XE011; AT25DF021; AT25DF021A; AT25XE021A
AT25XV021A; AT26DF041; AT25DF041A; AT25DF041B; AT25XE041D; AT25FF041A
AT25XV041B; AT25XE041B; AT25SF041; AT25SF041B; AT26DF081; AT26DF081A
AT25SF081; AT25SF081B; AT25XE081D; AT25FF081A; AT25SF161B; AT26DF161
AT26DF161A; AT25DF161; AT25XE161D; AT25FF161A; AT25SF321B; AT25SF321A
AT25DF321A; AT26DF321; AT25XE321D; AT25FF321A; AT25SF641B; AT25SF641
AT25QF641; AT25DF641A; AT25QF641B; AT25SF128A; AT25QF128A; AT25DF081[1.8V]*
AT25DL081[1.8V]*; AT25DL161[1.8V]*; AT25SL321[1.8V]*; AT25QL321[1.8V]*
AT25SL641[1.8V]*; AT25QL641[1.8V]*; AT25SL128A[1.8V]*; AT25QL128A[1.8V]*
AMIC:
A25L05PT; A25L05PU; A25L10PT; A25L10PU; A25L20PT; A25L20PU; A25L40PT
A25L40PU; A25L80PT; A25L80PU; A25L16PT; A25L16PU; A25L512; A25L010
A25L020; A25L040; A25L080; A25L016; A25L032; A25LQ16; A25LQ32; A25LQ64
ATMEL:
AT25F512 (page = 128 bytes); AT25F1024x; AT25F2048x; AT25F4096x; AT26F004
AT25FS010; AT25FS040
ATO:
ATO25Q32
Berg_Micro:
BG25Q40A; BG25Q80A; BG25Q16A; BG25Q32A
BoyaMicro:
BY25D05; BY25D10; BY25D20; BY25D40; BY25D80; BY25D16; BY25Q32; BY25Q64
BY25Q128; BY25D20AW; BY25Q40AW; BY25Q80AW; BY25Q16AW; BY25Q20AL[1.8V]*
BY25Q40AL[1.8V]*; BY25Q80AL[1.8V]*; BY25Q16AL[1.8V]*; BY25Q32AL[1.8V]*
BY25Q64AL[1.8V]*; BY25Q128BL[1.8V]*; BY25Q16AL[1.8V]*; BY25Q32AL[1.8V]*
BY25Q64AL[1.8V]*; BY25Q128AL[1.8V]*
DOUQI:
DQ25Q64A
EON:
EN25B05; EN25B05T; EN25B10; EN25B10T; EN25B20; EN25B20T; EN25B40; EN25B40T
EN25B80; EN25B80T; EN25B16; EN25B16T; EN25B32; EN25B32T; EN25B64; EN25B64T
EN25F05; EN25F10; EN25F20; EN25F40; EN25F80; EN25F16; EN25F32; EN25F64
EN25LF05; EN25LF10; EN25LF20; EN25LF40; EN25P05; EN25P10; EN25P20
EN25P40; EN25P80; EN25P16; EN25P32; EN25P64; EN25Q40; EN25Q80A; EN25Q16A
EN25Q32; EN25Q32A; EN25Q32B; EN25Q64; EN25Q128; EN25QA32; EN25QA64
EN25QA128; EN25QH16; EN25QH32; EN25QH64; EN25QH128; EN25QH256; EN25T80
EN25T16; EN25S10[1.8V]*; EN25S20[1.8V]*; EN25S40[1.8V]*; EN25S80[1.8V]*
EN25S16[1.8V]*; EN25S32[1.8V]*; EN25S64[1.8V]*; EN25SX128[1.8V]*
ESMT:
F25L004A; F25L004A; F25L04UA; F25L008A; F25L008A; F25L016A; F25L01PA
F25L02PA; F25L04PA; F25S04PA; F25L08PA; F25L08QA; F25L16P; F25L16PA
F25L32PA; F25L32P; F25L32Q; F25L32QA; F25L64P; F25L64QA
EXCELSEMI:
ES25P10; ES25P20; ES25P40; ES25P80; ES25P16; ES25P32; ES25M40A; ES25M80A
ES25M16A
FIDELIX:
FM25Q08A; FM25Q16A; FM25Q16B; FM25Q32A; FM25Q64A; FM25Q128
FM:
FM25F005; FM25F01; FM25F02; FM25F04; FM25Q02; FM25Q04; FM25Q08; FM25Q16
FM25Q32; FM25Q64; FM25Q128; FM25W01; FM25W02; FM25W04; FM25W08; FM25W16
FM25W32; FM25W64; FM25W128
FMD:
FT25H02; FT25H04; FT25H08; FT25H16; FT25L02[1.8V]*; FT25L04[1.8V]*
GIANTEC:
GT25F512
GIGADEVICE:
MD25D20; MD25D40; MD25D80; MD25D16; GD25D40; MD25T80; GD25D80; GD25F40
GD25F80; GD25F256F; GD25Q512; GD25Q10; GD25Q20; GD25Q40; GD25Q80x
GD25Q16x; GD25Q32x; GD25Q64x; GD25Q127C; GD25Q128x; GD25Q256; GD25B512ME
GD55B01GE; GD55B02GE; GD25LQ05x[1.8V]*; GD25LQ10x[1.8V]*; GD25LQ20x[1.8V]*
GD25LQ40x[1.8V]*; GD25LQ80x[1.8V]*; GD25LQ16x[1.8V]*; GD25LQ32D[1.8V]*
GD25LQ64C[1.8V]*; GD25LQ128C[1.8V]*; GD25LQ256C[1.8V]*; GD25LT256C[1.8V]*
GD55LT512WE[1.8V]*
ICE:
ICE25P05 (page = 128 bytes)
INTEL:
QB25F016S33B; QB25F160S33B; QB25F320S33B; QB25F640S33B; QH25F016S33B
QH25F160S33B; QH25F320S33B
ISSI:
IS25LQ025; IS25LQ512; IS25LQ010; IS25LQ020; IS25LQ040; IS25LQ080B
IS25LQ016B; IS25LQ032B; IS25LQ020C; IS25LQ040C; IS25LQ080C; IS25LQ016C
IS25LQ032C; IS25LQ064; IS25LQ128; IS25LP025; IS25LP512; IS25LP010
IS25LP020; IS25LP040; IS25LP080; IS25LP016; IS25LP032; IS25LP064; IS25LP128
IS25LP256; IS25LP512; IS25LP01G; IS25WQ020[1.8V]*; IS25WQ040[1.8V]*
IS25WQ080[1.8V]*; IS25WP025[1.8V]*; IS25WP512[1.8V]*; IS25WP010[1.8V]*
IS25WP020[1.8V]*; IS25WP040[1.8V]*; IS25WP080[1.8V]*; IS25WP016[1.8V]*
IS25WP032[1.8V]*; IS25WP064[1.8V]*; IS25WP128[1.8V]*; IS25WP256[1.8V]*
IS25WP512[1.8V]*; IS25WP01G[1.8V]*
KHIC:
KH25L8036D
MACRONIX:
MX25L512; MX25L512A; MX25L512C; MX25L5121E; MX25L1005; MX25L1005A
MX25L1005C; MX25L1006E; MX25L1021E; MX25L1025C; MX25L1026E; MX25L2005
MX25L2005C; MX25L2006E; MX25L2026C; MX25L2026E; MX25L4005; MX25L4005A
MX25L4005C; MX25L4006E; MX25L4026E; MX25L8005; MX25L8006E; MX25L8008E
MX25L8035E; MX25L8036E; MX25L8073E; MX25L8075E; MX25L1605; MX25L1605A
MX25L1605D; MX25L1606E; MX25L1633E; MX25L1635D; MX25L1635E; MX25L1636D
MX25L1636E; MX25L1673E; MX25L1675E; MX25L3205; MX25L3205A; MX25L3205D
MX25L3206E; MX25L3208E; MX25L3225D; MX25L3233F; MX25L3235D; MX25L3235E
MX25L3236D; MX25L3237D; MX25L3239E; MX25L3273E; MX25L3273F; MX25L3275E
MX25L6405; MX25L6405D; MX25L6406E; MX25L6408E; MX25L6433F; MX25L6435E
MX25L6436E; MX25L6439E; MX25L6445E; MX25L6465E; MX25L6473E; MX25L6473F
MX25L6475E; MX25L6495F; MX25L6455E; MX25L12805D; MX25L12835E; MX25L12835F
MX25L12836E; MX25L12839F; MX25L12845E; MX25L12845G; MX25L12845F; MX25L12865E
MX25L12865F; MX25L12873F; MX25L12872F; MX25L12875F; MX25L12855E; MX25L25635E
MX25L25673G; MX25L25735E; MX25L51237G; MX25L51245G; MX25R512F; MX25R1035F
MX25R2035F; MX25R4035F; MX25R8035F; MX25R1635F; MX25R3235F; MX25R6435F
MX25U5121E[1.8V]*; MX25U1001E[1.8V]*; MX25U2032E[1.8V]*; MX25U2033E[1.8V]*
MX25U4032E[1.8V]*; MX25U4033E[1.8V]*; MX25U4035[1.8V]*; MX25U8032E[1.8V]*
MX25U8033E[1.8V]*; MX25U8035[1.8V]*; MX25U8035E[1.8V]*; MX25U1635E[1.8V]*
MX25U1635F[1.8V]*; MX25U3235E[1.8V]*; MX25U3235F[1.8V]*; MX25U6435F[1.8V]*
MX25U6473F[1.8V]*; MX25U12873F[1.8V]*; MX25U12835F[1.8V]*; MX25U25635F[1.8V]*
MX25U25673G[1.8V]*; MX25U51245G[1.8V]*; MX25UM51245G[1.8V]*; MX25V512
MX25V512C; MX25V512E; MX25V512F; MX25V1006E; MX25V1035F; MX25V2006E
MX25V2035F; MX25V4005; MX25V4006E; MX25V4035; MX25V4035F; MX25V8005
MX25V8006E; MX25V8035; MX25V8035F; MX25V1635F; MX66L1G45G; MX66U51235F[1.8V]*
MX66U1G45G[1.8V]*
MICRON:
N25Q016; N25Q032A; N25Q064A; N25Q064A[1.8V]*; N25Q0128A[1.8V]*; N25Q256A13
N25Q512A83; N25W032A11; N25W064A11; N25W128A11; N25W256A11; MT25QL128AB
MT25QL256A; N25Q0U64A[1.8V]*; N25Q0U128A[1.8V]*; MT25QU256AB[1.8V]*
MT25QU512A[1.8V]*; MT25QU01GB[1.8V]*; MT25QU02GC[1.8V]*; MT25QL512A
MT25QL01GB; MT25QL02GC; N25Q00AA13G
NANTRONICS:
N25S10; N25S20; N25S40; N25S16; N25S32; N25S80
PCT:
PCT25VF010A; PCT25LF020A; PCT25VF020A; PCT25VF040A; PCT25VF040B; PCT25VF080B
PCT25VF016B; PCT25VF032B
PFLASH:
Pm25LD256C; Pm25LV512A; Pm25LV010A; Pm25LV020; Pm25LV040; Pm25LV080B
Pm25LV016B; Pm25LD512; Pm25LD010; Pm25LD020; Pm25LQ512B; Pm25LQ010B
Pm25LQ020B; Pm25LQ040B; Pm25LQ080B; Pm25WQ080[1.8V]*; Pm25LQ016C; Pm25LQ032C
Pm25LQ064; Pm25LQ128; Pm25WD020[1.8V]*; Pm25WD040[1.8V]*
PMC:
PM25LD256_; PM25LD512_; PM25LD010_; PM25LD020_; PM25LD040_; PM25LV512_
PM25LV010_; PM25LV020_; PM25LV040_; PM25LV080_; PM25LV016_
PUYA:
P25D05H; P25D10H; P25D20H; P25D40H; P25D80H; P25D16H; P25Q05H; P25Q06H
P25Q10H; P25Q11H; P25Q20H; P25Q21H; P25Q40H; P25Q80H; P25Q16H; P25Q32H
P25Q64H; P25Q128H; P25Q256H; P25Q05U; P25Q10U; P25Q20U; P25Q40U; P25Q80U
P25Q16U; P25Q32U; P25Q64U; P25Q128U; P25Q256U; P25Q05L[1.8V]*; P25Q10L[1.8V]*
P25Q20L[1.8V]*; P25Q40L[1.8V]*; P25Q80L[1.8V]*; P25Q16L[1.8V]*; P25Q32L[1.8V]*
P25Q64L[1.8V]*; P25Q128L[1.8V]*; P25Q256L[1.8V]*
SANYO:
LE25FU106BMA; LE25FU206MA; LE25FU406BMA; LE25FW206M; LE25FW406M; LE25FW406AM
LE25FW806M; LE25W81; LE25U20A; LE25U40C; LE25S20[1.8V]*; LE25S40Q[1.8V]*
LE25S81[1.8V]*; LE25S161[1.8V]*
SPANSION:
S25FL001D; S25FL002D; S25FL004A; S25FL004D; S25FL008A; S25FL008D; S25FL016A
S25FL032A; S25FL032P; S25FL040A; S25FL040A_BOT; S25FL040A_TOP; S25FL064A
S25FL064P; S25FL128P; S25FL116K; S25FL132K; S25FL164K; S25FL064L; S25FL128L
S25FL256L; S25FL128S; S25FL256S; S25FL512S; S25FS064S[1.8V]*; S25FS128S[1.8V]*
S25FS256S[1.8V]*; S25FS512S[1.8V]*
SST:
SST25LF020A; SST25LF040A; SST25LF080A; SST25VF512A; SST25VF010; SST25VF010A
SST25VF020; SST25VF020A; SST25VF040; SST25VF040A; SST25VF080; SST25VF020B
SST25VF016B; SST25VF032B; SST25VF064C; SST25VF040B; SST25VF080B; SST25PF040C
SST26VF016; SST26VF032; SST26VF020A; SST26VF040A; SST26VF080A; SST26VF016B
SST26VF032B; SST26VF064B; SST26WF040B[1.8V]*; SST26WF080B[1.8V]*; SST26WF016B[1.8V]*
SST26WF032[1.8V]*; SST26WF064C[1.8V]*; SST25WF512[1.8V]*; SST25WF010[1.8V]*
SST25WF020[1.8V]*; SST25WF040[1.8V]*; SST25WF080[1.8V]*; SST25WF020A[1.8V]*
SST25WF040B[1.8V]*; SST25WF080B[1.8V]*
ST:
M45PE05*; M45PE10*; M45PE20*; M45PE40*; M45PE80*; M45PE16*; M45PE32*
M45PE64*; M25PE10; M25PE16; M25PE20; M25PE40; M25PE80; M25PE16; M25PE32
M25PE64; M25PE128; M25P05 (page = 128 bytes); M25P05A; M25P10 (page = 128 bytes)
M25P10A; M25P20; M25P20; M25P40; M25P40; M25P80; M25P80; M25P16; M25P32
M25P64; M25P128; M25PX80; M25PX16; M25PX32; M25PX64
UCUN:
UC25HQ40; UC25HQ80; UC25HQ16; UC25HQ32; UC25WQ40; UC25WQ80; UC25WQ16
UC25WQ32
WINBOND:
W25P10; W25P20; W25P40; W25P80; W25P16; W25P32; W25P64; W25Q10EW[1.8V]*
W25Q20CL; W25Q20EW[1.8V]*; W25Q20NE[1.2V]; W25Q40BL; W25Q40BV; W25Q40CL
W25Q40EW[1.8V]*; W25Q40NE[1.2V]; W25Q80BL; W25Q80BV; W25Q80JV; W25Q80EW[1.8V]*
W25Q80NE[1.2V]; W25Q16; W25Q16CL; W25Q16BV; W25Q16JV; W25Q16JV-xM
W25Q16FW[1.8V]*; W25Q16NE[1.2V]; W25Q32; W25Q32BV; W25Q32JV; W25Q32FV
W25Q32JV-xM; W25Q32FW[1.8V]*; W25Q32NE[1.2V]; W25Q32JW[1.8V]*; W25Q64JV-xM
W25Q64FV; W25Q64JV; W25Q64BV; W25Q64FW[1.8V]*; W25Q64NE[1.2V]; W25Q64JW[1.8V]*
W25Q128BV; W25Q128FV; W25Q128JV; W25Q128JV-xM; W25Q128FW[1.8V]*; W25Q128JW-xM[1.8V]*
W25Q256BV; W25Q256FV; W25Q256JV; W25Q256JV-xM; W25Q256JW[1.8V]*; W25Q256JW-xM[1.8V]*
W25Q512JV; W25Q512JV-xM; W25M512JV (2x256Mb Dies); W25M512JW[1.8V] (2x256Mb Dies)*
W25Q01JV (2x512Mb Dies); W25Q01JV-xM (2x512Mb Dies); W25X05; W25X05CL
W25X10AV; W25X10BL; W25X10BV; W25X10CL; W25X10L; W25X10V; W25D10; W25D20
W25X20AL; W25X20AV; W25X20BL; W25X20BV; W25X20CL; W25X20L; W25X20V
W25X40AL; W25X40AV; W25X40BL; W25X40BV; W25X40CL; W25X40L; W25X40V
W25D40; W25X80AL; W25X80AV; W25X80BV; W25X80L; W25X80V; W25D80; W25X16
W25X16AL; W25X16AV; W25X16BV; W25X16V; W25X32; W25X32AV; W25X32BV
W25X32V; W25X64; W25X64BV; W25X64V
XMC:
XM25QH10B; XM25QH20B; XM25QH40B; XM25QH80B; XM25QH16x; XM25QE16B; XM25QH32B
XM25QE32B; XM25QH64A; XM25QH64B; XM25QH128A; XM25QH128B; XM25QH128C
XM25QH256B; XM25QW16C; XM25QW32C; XM25QW64C; XM25QW128C; XM25QW256C
XM25QU41B[1.8V]*; XM25QU80B[1.8V]*; XM25QU16C[1.8V]*; XM25QU32C[1.8V]*
XM25QU64A[1.8V]*; XM25QU64B[1.8V]*; XM25QU64C[1.8V]*; XM25QU128B[1.8V]*
XM25QU128C[1.8V]*; XM25QU256B[1.8V]*
XTX:
XT25F01B; XT25F02B; XT25F04B; XT25F08B; XT25F16B; XT25F32B; XT25F64B
XT25F128B; XT25W02E; XT25W04D; XT25Q08D[1.8V]*; XT25Q16D[1.8V]*; XT25W32B
XT25Q64D[1.8V]*; XT25Q128D[1.8V]*
Zetta:
ZD25D20; ZD25D40; ZD25D80; ZD25D16; ZD25Q20A; ZD25Q40A; ZD25Q80A; ZD25Q16A
ZD25Q32A; ZD25Q64A; ZD25Q128; ZD25Q256; ZD25Q512; ZD25LQ64A[1.8V]*
ZD25LQ128A[1.8V]*; ZD25WD40B
Zbit:
ZB25WD20; ZB25WD40; ZB25WD80; ZB25WD16; ZB25D20; ZB25D40; ZB25D80
ZB25D16; ZB25VQ20; ZB25VQ40; ZB25VQ80; ZB25VQ16; ZB25VQ32; ZB25VQ64
ZB25VQ128; ZB25VQ256; ZB25LQ20[1.8V]*; ZB25LQ40[1.8V]*; ZB25LQ80[1.8V]*
ZB25LQ16[1.8V]*; ZB25LQ32[1.8V]*; ZB25LQ64[1.8V]*; ZB25LQ128[1.8V]*
ZB25LQ256[1.8V]*
SPI EEPROM*******
APLUS:
AF25BC08; AF25BC16; AF25BC32; AF25BC64; AF25BC128; AF25BC256
ATMEL:
AT25010[5.0V]; AT25020[5.0V]; AT25040[5.0V]; AT25080[5.0V]; AT25160[5.0V]
AT25320[5.0V]; AT25640[5.0V]; AT25128[5.0V]; AT25256[5.0V]; AT25512[5.0V]
AT25010-x; AT25020-x; AT25040-x; AT25080-x; AT25160-x; AT25320-x; AT25640-x
AT25128-x; AT25256-x; AT25512-x; AT25HP256; AT25HP512
CATALYST_CSI:
CAT25010; CAT25020; CAT25040; CAT25080; CAT25160; CAT25320; CAT25640
CAT25128; CAT25256; CAT25C01; CAT25C02; CAT25C03; CAT25C04; CAT25C05
CAT25C08; CAT25C09; CAT25C16; CAT25C17; CAT25C32; CAT25C33; CAT25C64
CAT25C65; CAT25C128; CAT25C256
GIANTEC:
GT25C01; GT25C02; GT25C04; GT25C08; GT25C16; GT25C32; GT25C32A; GT25C64
GT25C128; GT25C128A; GT25C256
ICMIC:
X25020; X25021; X25040; X25041; X25080; X25160; X25170; X25320; X25330
X25640; X25642; X25650; X25128
INTEGRAL:
IN25AA020; IN25AA040; IN25AA080; IN25AA160
ISSI:
IS25C01; IS25C02; IS25C04; IS25C08; IS25C16; IS25C32; IS25C64; IS25C128
IS25C256
MICROCHIP:
25AA010A; 25AA020A; 25AA040; 25AA040A; 25AA080; 25AA080A; 25AA080B
25AA080C; 25AA080D; 25AA1024; 25AA128; 25AA160; 25AA160A; 25AA160B
25AA256; 25AA320; 25AA512; 25AA640; 25C040[5.0V]; 25C080[5.0V]; 25C160[5.0V]
25C320[5.0V]; 25C640[5.0V]; 25LC010A; 25LC020A; 25LC040; 25LC040A
25LC080; 25LC080A; 25LC080B; 25LC080C; 25LC080D; 25LC128; 25LC160
25LC160A; 25LC160B; 25LC320; 25LC640; 25LC256; 25LC512; 25LC1024
RENESAS:
HN58X2502; HN58X2504; HN58X2508; HN58X2516; HN58X25256; HN58X2532
HN58X2564; R1EX25002A; R1EX25004A; R1EX25008A; R1EX25016A; R1EX25032A
R1EX25064A
ROHM:
BR25010; BR25020; BR25040; BR25080; BR25160; BR25320; BR25H010; BR25H020
BR25H040; BR25H080; BR25H160; BR25H320; BR25L010; BR25L010; BR25L020
BR25L040; BR25L080; BR25L160; BR25L320; BR25L640; BR25S320; BR25S640
BR25S128; BR25S256; BR25G512; BR25G1M; BR95010; BR95020; BR95040; BR95080
BR95160
SAIFUN:
SA25C1024; SA25C512
SEIKO:
S-25A010A; S-25A020A; S-25A040A; S-25A080A; S-25A160A; S-25A320A; S-25A640A
S-25C010A; S-25C020A; S-25C040A; S-25C080A; S-25C160A; S-25C320A; S-25C640A
ST:
M25C16; M25W16; M35080-Vx[5.0V] (Erase of ‘Data Secure Array’ is not supported)*
M35080-3-6[5.0V] (Erase, write of ‘Data Secure Array’ is supported)*
080D0Wx[5.0V] (Erase of ‘Data Secure Array’ is not supported)*; M35160[5.0V] (Erase of ‘Data Secure Array’ is not supported)*
M95010[5.0V]; M95010R; M95010W; M95020[5.0V]; M95020R; M95020W; M95040[5.0V]
M95040R; M95040W; ST95P02; ST95P04; ST95P08 (5P08 5P08C3 95P08); M95080[5.0V]
M95080R; M95080W; M95128[5.0V]; M95128R; M95128W; M95160[5.0V]; M95160R
M95160W; M95256[5.0V]; M95256R; M95256W; M95320[5.0V]; M95320R; M95320W
M95512R; M95512W; M95640[5.0V]; M95640R; M95640W; M95M01R; M95M01W
M95M02
XICOR:
X25010; X25043; X25045; X25F008; X25F016; X25F032; X25F064; X5043[5.0V]
X5045[5.0V]
SPI FRAM*********
CYPRESS:
FM25040; FM25160; FM25640; FM25CL04; FM25CL64; FM25L16; FM25L256; FM25L512
FM25W256; FM25L04B; CY15E004Q; FM25L16B; CY15E016Q; FM25CL64B; CY15E064Q
CY15B128Q; FM25V01A; FM25V02; FM25V05; FM25V10; FM25VN10; FM25V20
CY15B102Q; CY15B104Q; CY15B102QN-50SXE; CY15B104Q-PZXI; CY15B104QN-50SXA
CY15B104QN-20LPXC; CY15B104QN-20LPXI; CY15B104QN-50LPXI; CY15B104QI-20LPXC
CY15B104QI-20LPXI; CY15B104QSN; CY15B108QN-40SXI; CY15B108QN-20LPXC
CY15B108QN-20LPXI; CY15B108QI-20LPXC; CY15B108QI-20LPXI; CY15V102QN-50SXE[1.8V]*
CY15V104QN-50SXI[1.8V]*; CY15V104QN-20LPXC[1.8V]*; CY15V104QN-20LPXI[1.8V]*
CY15V104QI-20LPXC[1.8V]*; CY15V104QI-20LPXI[1.8V]*; CY15V104QSN[1.8V]*
CY15V108QN-20LPXC[1.8V]*; CY15V108QN-20LPXI[1.8V]*; CY15V108QN-40LPXI[1.8V]*
CY15V108QI-20LPXC[1.8V]*; CY15V108QI-20LPXI[1.8V]*
EVERSPIN:
MR25H128; MR25H256; MR25H10; MR25H40
FUJISU:
MB85RS16; MB85RS64; MB85RS64V; MB85RS64T; MB85RS128B; MB85RS128T; MB85RS256B
MB85RS256T; MB85RS512T; MB85RS1MT; MB85RS2MT; MB85RS4MT; MB85RDP16L[1.8V]*
MB85RS2ML[1.8V]*
LAPIS:
MR45V032; MR45V064; MR45V256; MR45V100
I2C 24 EEPROM****
Generic:
24C01_no_addr (no address); 24C00; 24C01[5.0V]; 24C02; 24C04; 24C08
24C16; 24C32; 24C64; 24C128; 24C256; 24C512; 24C1024; 24C2048
ATMEL:
AT24RF08C*; AT24C01_no_addr (no address)
MICROCHIP:
24LC515[5.0V]*; 24LC1025[5.0V]*; 24LC1026[5.0V]*
CHEMTRONICS:
CT1C08*; CT1C16*
Philips:
PCF8582A[5.0V]*; PCF8582C*; PCA9500*
ST:
M24M01; M24M02
TOSHIBA:
TC9WMB1F; TC9WMB2F; TC9WMB4F
XICOR:
X24C01_no_addr (no address); X24165 (with protection register); X24325 (with protection register)
X24645 (with protection register)
I2C 24 FRAM******
CYPRESS:
FM24C04x[5.0V]; FM24C16x[5.0V]; FM24C32x[5.0V]; FM24C64x[5.0V]; FM24W256
FM24CL04; FM24CL16; FM24CL32; FM24CL64; FM24V01; FM24V02; FM24V05
FM24V10
I2C SPD EEPROM***
ST-ATMEL:
AT34C02*; AT34C04*; M34E02*; M34E04*
MICROWIRE EEPROM*
Generic:
93C86_8bits[5.0V]*; 93C86_16bits[5.0V]*; 93C76_8bits[5.0V]*; 93C76_16bits[5.0V]*
93C66_8bits[5.0V]*; 93C66_16bits[5.0V]*; 93C57_8bits[5.0V]*; 93C57_16bits[5.0V]*
93C56_8bits[5.0V]*; 93C56_16bits[5.0V]*; 93C46_8bits[5.0V]*; 93C46_16bits[5.0V]*
93C06_16bits[5.0V]*; 93LC86_8bits*; 93LC86_16bits*; 93LC76_8bits*
93LC76_16bits*; 93LC66_8bits*; 93LC66_16bits*; 93LC57_8bits*; 93LC57_16bits*
93LC56_8bits*; 93LC56_16bits*; 93LC46_8bits*; 93LC46_16bits*; 93AA86_8bits*
93AA86_16bits*; 93AA76_8bits*; 93AA76_16bits*; 93AA66_8bits*; 93AA66_16bits*
93AA57_8bits*; 93AA57_16bits*; 93AA56_8bits*; 93AA56_16bits*; 93AA46_8bits*
93AA46_16bits*
AKM:
AK93C10A_16bits[5.0V]*; AK93C95A_16bits[5.0V]*; AK93C85A_16bits[5.0V]*
AK93C75A_16bits[5.0V]*; AK93C65A_16bits[5.0V]*; AK93C55A_16bits[5.0V]*
AK93C45A_16bits[5.0V]*; AK6416A_16bits (NO detection)*; AK6480A_16bits (NO detection)*
AK6440A_16bits (NO detection)*; AK6420A_16bits (NO detection)*
CATALYST:
CAT33C201_16bits*; CAT33C201_8bits*; CAT33C204_8bits*; CAT33C204_16bits*
CAT35C204_8bits[5.0V]*; CAT35C204_16bits[5.0V]*; CAT35C108_8bits[5.0V]*
CAT35C108_16bits[5.0V]*
CYPRESS:
CY93C16_8bits*; CY93C16_16bits*; CY93C08_8bits*; CY93C08_16bits*; CY93C04_8bits*
CY93C04_16bits*; CY93C02_8bits*; CY93C02_16bits*; CY93C01_8bits*; CY93C01_16bits*
ST_93Sx6:
M93S66_16bits*; M93S56_16bits*; M93S46_16bits*
DIV_59x:
ER5912_8bits[5.0V]*; ER5912_16bits[5.0V]*; ER5911_8bits[5.0V]*; ER5911_16bits[5.0V]*
ER59256_16bits[5.0V] (Connect Pin 7 to GND)*; AT59C13_8bits[5.0V]*
AT59C13_16bits[5.0V]*; AT59C22_8bits[5.0V]*; AT59C22_16bits[5.0V]*
AT59C11_8bits[5.0V]*; AT59C11_16bits[5.0V]*
MITSUBISHI:
M6M80011_16bits[5.0V] (NO detection)*; M6M80021_16bits[5.0V] (NO detection)*
M6M80041_16bits[5.0V] (NO detection)*
NSC:
NM93C14_16bits[5.0V]*; NM93C13_16bits[5.0V]*; NMC9306_16bits[5.0V]*
NMC9307_16bits[5.0V]*
OKI:
M811P_8bits[5.0V]*; M811P_16bits[5.0V]*; MSM16811_8bits[5.0V]*; MSM16811_16bits[5.0V]*
MSM16951_8bits[5.0V]*; MSM16951_16bits[5.0V]*; MSM16931_8bits*; MSM16931_16bits*
MSM16912_8bits[5.0V]*; MSM16912_16bits[5.0V]*; MSM16911_8bits[5.0V]*
MSM16911_16bits[5.0V]*
ROHM:
BR9010_16bits (NO detection)*; BR9020_16bits (NO detection)*; BR9020_8bits (NO detection)*
BR9040_16bits (NO detection)*; BR9080_16bits (NO detection)*; BR9016_16bits (NO detection)*
BR9021_16bits[5.0V] (NO detection)*; BR9041_16bits[5.0V] (NO detection)*
BR9010F_16bits (NO detection)*; BR9020F_16bits (NO detection)*; BR9040F_16bits (NO detection)*
BR9080F_16bits (NO detection)*; BR9016F_16bits (NO detection)*; BR9021xF_16bits[5.0V] (NO detection)*
BR9041xF_16bits[5.0V] (NO detection)*
SONY:
CXK1011P_8bits[5.0V] (NO detection)*; CXK1012P_8bits[5.0V] (NO detection)*
CXK1013P_8bits[5.0V] (NO detection)*; CXK1024P_8bits[5.0V] (NO detection)*
TOSHIBA:
TC89101P_8bits[5.0V] (NO detection)*; TC89101P_16bits[5.0V] (NO detection)*
TC89102P_8bits[5.0V] (NO detection)*; TC89102P_16bits[5.0V] (NO detection)*
TC89121P_8bits[5.0V] (NO detection)*; TC89122P_8bits[5.0V] (NO detection)*
TC97101P_8bits[5.0V] (NO detection)*; TC9WMA1FK_8bits (NO detection)*
TC9WMA2FK_8bits (NO detection)*
AVR***
ATtiny:
ATtiny12*; ATtiny15*; ATtiny22*; ATtiny13*; ATtiny2313*; ATtiny24*
ATtiny25*; ATtiny26*; ATtiny261*; ATtiny4313*; ATtiny43U*; ATtiny44*
ATtiny441*; ATtiny45*; ATtiny461*; ATtiny48*; ATtiny828*; ATtiny84*
ATtiny841*; ATtiny85*; ATtiny861*; ATtiny87*; ATtiny88*; ATtiny167*
ATtiny1634*
ATmega:
ATmega48*; ATmega48P*; ATmega48PB*; ATmega8*; ATmega88*; ATmega88P*
ATmega88PB*; ATmega8515*; ATmega8535*; ATmega16*; ATmega161*; ATmega162*
ATmega163*; ATmega164*; ATmega164P*; ATmega165*; ATmega165P*; ATmega168*
ATmega168P*; ATmega168PB*; ATmega169*; ATmega169P*; ATmega32*; ATmega324*
ATmega324P*; ATmega324PA*; ATmega324PB*; ATmega325*; ATmega325P*; ATmega3250*
ATmega3250P*; ATmega328*; ATmega328P*; ATmega328PB*; ATmega329*; ATmega329P*
ATmega3290*; ATmega3290P*; ATmega64*; ATmega640*; ATmega644*; ATmega644P*
ATmega645*; ATmega645P*; ATmega6450*; ATmega6450P*; ATmega649*; ATmega649P*
ATmega6490*; ATmega6490P*; ATmega128*; ATmega1280*; ATmega1281*; ATmega1284*
ATmega1284P*; ATmega2560*; ATmega2561*
specific:
AT90USB82*; AT90USB162*; AT90USB646-7*; AT90USB1286-7*; ATmega8U2*
ATmega16U2*; ATmega16U4*; ATmega32U2*; ATmega32U4*; AT90CAN32*; AT90CAN64*
AT90CAN128*; ATmega16M1*; ATmega32C1*; ATmega32M1*; ATmega64C1*; ATmega64M1*
AT90PWM2-3*; AT90PWM2B-3B*; AT90PWM81*; AT90PWM161*; AT90PWM216-316*
ATmega16HVB*; ATmega32HVB*; ATmega32HVE*; ATmega64HVE*; ATmega128RFA1*
ATmega64RFR2*; ATmega128RFR2*; ATmega256RFR2*; ATmega644RFR2*; ATmega1284RFR2*
ATmega2564RFR2*
AT90Sxxxx:
AT90S1200[5.0V]*; AT90S2313[5.0V]*; AT90S2323[5.0V]*; AT90S2343[5.0V]*
AT90S4414[5.0V]*; AT90S4434[5.0V]*; AT90S4433[5.0V]*; AT90S8515[5.0V]*
AT90S8535[5.0V]*; AVR_Locked[5.0V] (ID=0x00,0x01,0x02)*
MCU***
NUVOTON:
N76E003_locked (Locked)*; N76E003*; N76E616; N76E885
The Car code decoder program works with the eeprom file. It supports the models in the list below.
Alpine MF2197 (24c02)
Alpine MF2199 -Audio 10 (24c04)
Alpine MF2910 -Audio 10 (24c04)
Chrysler-P05091605().6.B (9S120G256)
Autosound (DK1012)
Audi RNS-E AISIN AW (2L120F)
Blaupunkt[Z1Z3) Audi Concert 2+
Blaupunkt[Z1Z4) Audi Symphony 2+
Blaupunkt RCD 200/300/500
Blaupunkt (25160)
Blaupunkt FIAT /NISSAN (95320)
Blaupunkt WOOOST OCK (95640)
Blaupunkt Los Angeles MP72 (95320)
Blaupunkt C030 MP3 (95640)
Blaupunkt BOSH (Suzuki lgnis)
Blaupunkt GAMMA VWZ1Z3 (95160)
Blaupunkt Alpha CC VWZ1Z1 (24c01)
MB TRUCK BAS E LOW (95320)
Delco COR 500/2005 (TMS370)
Delphi Delta 6 [Z4Z4) V1 &V2
Delphi RCO 200 [Z4Z4) V1 &V2
Delphi New Bettle Monsoon [Z4Z5)
Delphi New Bettle Monsoon [Z4Z7)
FamarVWZ4Z3 (24cOB)
VW Premium 5 Z4Z7 (9355092)
Delphi Premium? VZ4Z.7 (24C16)
Ford TB9121T-9123T (24C01)
Grundia 24CfAudi/Seat/Skoda/Smartl
Grundig 24C(Audi/Seat/Skoda/Smart)
Grundig CAR 2002 (24C01)
Grundig 6BHC11AB/E9/KA4
Grundig EC7xxx (HC11 P2)
Grundig RCD300 (24c32)
Honda made by Alpine (93c46)
swap Honda CQ-EHB4B!E (24C04)
KIA made by Alpine (24c01)
Pioneer BMW KE-92ZBM (P21 OOR)
Pioneer BMW KE -93ZBM (P21 OOR)
Pioneer DEH/KEH (PDG011)
Pioneer DEH-2006 Renault (PDH004)
Volvo (some models)
Philips Renault (24c32/24c64)
Philips CAR400/2004. CCRS00/2006
Philips CAR600/CCRBOO. CDC3 CART2007. CCRT7D0/200B (2BC64) VDD CDR500/2005
VDD MS4150RS Navi (24c32)
Medion 41400 Navi (24c32)
Rover CD-BO
Rover 75 (Philips)
Rover (Alpine)
Rover Cd213x/413x
Pioneer BMW KE -92ZBM (P21 OOR)
Volvo (some models)
Philips CAR400/2004. CCR600/2006
Carminat RENRNC4DO-OO (24c64)
VDO MS4150RS Navi (24e32)
Rover CD-BO
Rover 75 (Philips)
Rover Al ine
Seat Scala (25160)
Seat SE350 SEZ1Z3 (95640)
Sony MBOO/B50/BBDO (24C02)
CH341A programmer 95460 and Other Adapter Diagrams
CH341A Kicad PCB, schematic and List of download LINK for all programs (in TXT format) 28621a.zip pass: 320volt.com
Publication date: 2022/11/17 Tags: programmer circuit
