Button to Display Number Control Hi Tech C Example
| Updated on September 4, 2024
Pressing the first button in this application increased the number of digits shown in the display, the second reduced the number of digits after pressing the button, the last button is pressed, the display will be shown only 0.
To make this process display () function to display the maximum number to be scanned in the set. This is how many numbers displayed on the screen if the application only display that is scanned.
Display Number ControlCircuit diagram
hi-tech-c-sample-button-display-buton-ile-displayde-sayi-kontrolu
Hi tech c Button display example proteus isis and code files:
Publication date: 2011/01/14 Tags: , ,
1 Comment “Button to Display Number Control Hi Tech C Example
    Variable number of display Hi Tech C Example
    Very nice Hi tech C examples we are here . In this application a variable defined as longer displayed on the screen that will examine how the number . tmp sequence numbers assigned to the same are shown on the display . The first button is pressed, the value of one variable increases, the second button is pressed, the value of the num variable is decreased by 1 , the last button is pressed, the num variable is assigned to 0 .
    Num variable values ​​on the display are divided into steps before the show . In a number of steps to get the mode field with 10% , ie, the number 10 and the remainder calculated tmp [0] in the first step of assigning a display is provided on the display .
