Atmel ATtiny45 Bluetooth Scoreboard Circuit
| Updated on August 3, 2019
The scoreboard circuit is based on Atmel microcontroller ATtiny45 circuit cell phone can be controlled via bluetooth, the bluetooth module used in the indicator circuit BTM400-6B is an LCD TV has VGA output of the circuit for the project and Android Bluetooth communication codes Scoreboard attiny45 eagle pcb, there is a very useful resource schema diagrams
Note: the library does not have schema attiny13 attiny45 used eagle looks microcontroller attiny45
Bluetooth Scoreboard This project aims to display a scoreboard in a regular VGA monitor, remotely controlled with an Android device (cellphone, tablet) via Bluetooth. Bluetooth module BTM400-6B will wait for a connection from a device (e.g. an Android phone) and will act as an Serial Port Profile re-passing everything received from the device to the UART interface. In our case the ATtiny will read the data but won’t “speak back” to the module, so it’s really a one way communication from that point of view. pretty simple: control a ping-pong electronic scoreboard from an Android bluetooth-enabled device. To do this, I used an ATtiny45 which main function is to display the current scores in a VGA monitor while reading from a bluetooth module UART interface waiting for “commands” that will tell it what to display. The Android device sends the commands via bluetooth, running an application specially designed for this project. As usual, the whole project is open source, including schematics, AVR firmware and the Android application.
electronic-scoreboard-btm400-6b-android-bluetooth-scoreboard-circuit
electronic-scoreboard-from-an-android-bluetooth-scoreboard-circuit
scoreboard-vga-monitor-20mhz-attiny-atmelexternal-oscillator
Source: alfersoft.com.ar/blog/category/elec/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19660.zip
Publication date: 2012/09/08 Tags: ,
2 Comments “Atmel ATtiny45 Bluetooth Scoreboard Circuit
    Serial Connection with Power Supply Voltage Up
    How healthy is the serial port Power supply stable, but the location is questionable when it comes to PC power supplies connected in series and it just works (at, ATX) 10v …. Able to raise the voltage from 48v same characteristics in different SMPS or resources that will power transformer.
    Especially amateur CNC projects pc power supplies Frequently used it in series mesh if the author ATX power supply series is connected but 5v and 3.3v output to connect a load got to or more power can not be the SMPS switches off all used power supply 5V and – between the 4.7ohm 10w 3.3v and – 10w 3ohm resistance necessary to connect between the stone and the voltage can be increased after the series baklant
    Atmel ATtiny45 Bluetooth Anzeigetafel Schaltung
    Die Anzeigetafel Schaltung basiert auf Atmel Mikrocontroller ATtiny45 Schaltung Handy kann über Bluetooth gesteuert werden, das Bluetooth-Modul in der Anzeige Schaltung BTM400-6B ist ein LCD-TV hat VGA-Ausgang der Schaltung für das Projekt und Android Bluetooth-Kommunikation Codes Anzeigetafel attiny45 Adler pcb gibt es sehr nützliche Ressourcenschemadiagramme
    Hinweis: Die Bibliothek hat kein Schema attiny13 attiny45 used adler sieht Mikrocontroller attiny45
    Bluetooth Scoreboard Dieses Projekt zielt darauf ab, eine Anzeigetafel in einem normalen VGA-Monitor anzuzeigen, ferngesteuert mit einem Android-Gerät (Handy, Tablet) über Bluetooth. Das Bluetooth-Modul BTM400-6B wartet auf eine Verbindung von einem Gerät (z. B. einem Android-Telefon) und fungiert als serielles Port-Profil, das alle vom Gerät empfangenen Daten an die UART-Schnittstelle weitergibt. In unserem Fall wird der ATtiny die Daten lesen, aber nicht zu dem Modul “sprechen”, daher ist es wirklich eine Einwegkommunikation aus dieser Sicht. Ziemlich einfach: Kontrollieren Sie eine Ping-Pong-Anzeigetafel von einem Android-Gerät mit Bluetooth-Funktion. Um dies zu tun, habe ich ein ATtiny45 verwendet, dessen Hauptfunktion es ist, die aktuellen Punkte in einem VGA-Monitor anzuzeigen, während man von einem UART-Interface des Bluetooth-Moduls liest und auf “Befehle” wartet, die ihm sagen, was angezeigt werden soll. Das Android-Gerät sendet die Befehle über Bluetooth und führt eine speziell für dieses Projekt entwickelte Anwendung aus. Wie üblich ist das gesamte Projekt Open Source, einschließlich Schaltpläne, AVR-Firmware und der Android-Anwendung.
