Computer-Controlled LED Scrolling Message Display Temperature Humidity etc.
| Updated on September 14, 2023
LED Scrolling Message Display circuit Prepared by: Atila ULUDAĞ – Computer-controlled scrolling marquee application SHT11 DS1302 PIC18F452, MAX485 74HC595 (scan lines) based on the integrated computer software designed to control and c language source code in Visual Basic has been prepared by the PIC software.
You can send text marquee circuit via computer date, time, temperature, neb information shows
I do not know if it works but the source code of the application is given of the different projects can be useful in
LED Scrolling Message Display Schematic
kayan-yazi-devresi-dijital-pano-led-tabela
LED Scrolling Message circuit schematic visual basic control and code files:
Publication date: 2010/02/23 Tags: ,
1 Comment “Computer-Controlled LED Scrolling Message Display Temperature Humidity etc.
    High Efficiency PWM LED Dimmer Control Circuit
    Led dimmer PWM circuit with LM358 opamp technique used can be used as LED flashlight. All information about the project ( provided.
    High Efficiency PWM LED Dimmer Control Circuit beyaz led pwm el feneri This webpage describes a highly efficient LED dimmer, or a dimmable LED flashlight, or a switching current source, or whatever you want to call it. Cheap, single-IC, uses commonly available parts, easy to build. Designed to get the longest light out of a (rechargable) battery, ideal in emergency situations: some 24+ hours for a single white LED at full brightness from a cheap 9V, 200mAh battery. Works well from 4 up to at least 30 Volts; may even vary over time, while the brightness level is maintained essentially constant. Can drive as many LEDs
    PWM LED Driver Circuit
