Servo motor control circuit assembly prepared with software installed on PIC16F84 microcontroller. Computer monitoring software designed with Visual Basic can control 8 low-power servo motor circuit and the communication between the PC via RS232 serial port built
The program is written in VISUALBASIC and comes complete with source so you can personalize the interface. The circuit uses the popular PIC 16F84, on it there is also a very simple interface for dialogue with the PC via RS232.
RS232 Servo Motor Control Program
The program has a simple interface to a separate source (. VBW,. FRx. VLPs,. Frm) Visual Basic dosyalarıda’s operation of the program to C: \ WINDOWS \ system32 folder MsComm32.ocx, vb6fr.dll files should be
PIC16F84 Servo Motor Drive Circuit
source : http://www.adrirobot.it PIC16F84 Servo Motor Control circuit files alternative link:
Published: 2010/03/08 Tags: microchip projects, microcontroller projects, pic16f84 projects
CNC Milling Machine for Drilling Drive Control Circuits
Motor driver board for CNC Machine L297, L298 author conducted with integrated 3 axis control circuit for each engine used. LPT parallel port that communicates with the computer is done via the ULN2803 circuit and built on PC849 opto
For controlling the motors I’m using a chopper controller that works with L297 and L298 ic. The components therefor I’m going to pick up a few control print I received (see below). Rik The reason that I do not use print as they are is because if you adhere to a stepper motor that immediately begins to turn and the steering is not really universal.
CNC Circuit
