PIC16F877 Digital Logic Integrated Test TTL IC Tester Circuit
| Updated on August 19, 2023
EPE magazine free distribute a project is actually a previous post could be added, but I want to isolate because too different circuit digital logic ICs with that circuit will test you can install on your computer that you program with visual tested as integrated data can be seen
Circuit PIC16F877 based on computer communication MAX232 RS232 port provided for connection ZIF socket, thanks in different sizes integrated, can be tested source asm and hex software’s test phase circuit operating principle and explains in detail (english) also cable Shamash is in
lojik-entegre-test-devresi-150x150 dijital-lojik-entegre-test-150x150
PIC16F877 Digital Logic Integrated Test TTL IC tester Circuit schematic source code etc. files
Publication date: 2009/05/31 Tags: , ,
1 Comment “PIC16F877 Digital Logic Integrated Test TTL IC Tester Circuit
