Transistor BD137 is used Temperature Sensor Fan Control Circuit
| Updated on August 5, 2024
In general, the LM35 temperature sensor in the control circuits, integrated dsxx series used in this application BD137 NPN transistor used as a sensor control circuit project fully regulated by a fan skies, has a printed circuit.
isi-sensoru-devre-semasi
Temperature control circuit files and details of: control de temperatura
Publication date: 2010/11/20 Tags:
1 Comment “Transistor BD137 is used Temperature Sensor Fan Control Circuit
    A Design Classic Transistor Flip-Flop Circuit Simulation
    A lot of people interested in electronics applied a variation of the classic two-transistor flip flop circuit design using 2 different operating states provided the same circuit. LEDs are enabled 6.
    first transistor T1 now suppose that the message (D4 -D3 BURN OFF ) . In this case T1 collector voltage will be closer to zero volts, and for the first time would be short-circuited capacitor C1 to bias the base of transistor T2 and T2 will fall will enter into insulation . Capacitor C1 through resistor R3 is the base bias of transistor T2 times of charging will increase relatively .
