Simple Auto Robot PIC16F628 H-Bridge Motor Driver Circuit
| September 11, 2024 Updated
Microchip PIC series microcontrollers prepared with a very robotic circuit’s this circuit compared to the others a bit more simple, right, left controls the keys is done with the development of an open car robot circuit to control the PIC16F628 used motor speed as the bridge is driven driver transistors in the BD series low-power transistors can use
Auto robot project assembly prepared by the PIC source software has asm and hex codes sprint layout pcb drawing of the robot project and spline drawing the scheme have 4.5 or 5v power supply circuit or battery operated.
robot-oto-robotlar-car-robots-h-bridge-motor-motors
pic16f628-robot-oto-tekerlek-robotlar-car-robots-hbridge-motor-motors
oto-robot-devre-semasi
Published: 2011/06/22 Tags: , ,
1 Comment “Simple Auto Robot PIC16F628 H-Bridge Motor Driver Circuit
    Class A Hi Fi Amplifier Circuit AlephM
    Aleph-M output power is approximately 35W Class A class amp for quite a good value output MODFET n channel 2 irfp240 used supply voltage with symmetric +-18v dc Aleph-M PCB schematics, layout drawings have additional supply circuit diagram’s. Because the class is Anfi in SUPPLY CIRCUIT quite a lot of quality material already amp circuit feed price is high abundance 2.2mh coil used as a filter.
