Power electronics for power tests after a period of difficulty in trying to use the lamp aşlıyor and often what you crave is easier to set up a variety of cargo systems work resources.
A variety of power sources, test circuit only used Kenwood, based on electronic load circuit transistor opamplar atmega88 micro-controller based on the lcd display can be set in the advanced version of the load circuit of power 100w 2 potentiometer precision can be set on the circuit.
Dummy Load Circuit Electronic Load Test
Protel pcb project’s source code and have the schema files, IAR. Source: http://bsvi.ru/aktivnaya-nagruzka/ alternative
Active Electronic Load Circuit ATmega88 100w Dummy Load
Publication date: 2011/01/12 Tags: avr project, microcontroller projects
Computer VU Meter Circuit with LPT Port LED Control
The computer’s LPT port used in the simple led circuit (only consists of led and resistors) and control program can be a variety of effects or with vu meter WndLpt program contains plug-ins with Winamp 5 in effects, WMP, Windows Media Player, supports Aimp2 programs.
