The presented project is a function generator for sinusoidal and square signals production. The output frequency covers the range from 10 Hz to 100 KHz with a step of 2 Hz.
The waveform synthesis is based on the D.D.S. technique (Direct Digital Synthesis) and the output frequency is selected through a microcomputer with an embedded thumb wheel keyboard.
Function Generator Technical specifications
Output Frequency: 10 Hz – 100 KHz (step 2 Hz)
Output Voltage:
Sinus: 0 – 20 Vp-p
Square: 0 – 20 Vp-p
TTL: 5 V
Output Resistance: 1 KOhms
Function Generator Sinusoidal waveform direct digital synthesis
A complete sinusoidal waveform can be synthesized through a D.D.S. system. This system uses a group of 2^21 phases (time slots) and a 16 bit data latch defines how many of them will be contained between two successive synchronization pulses. If the 16 bit data latch contains low numerical values then the output frequency will be low and if the 16 bit data latch contains high numerical values then the output frequency will be high.
source: http://www.seattlerobotics.org/encoder/200205/ddsfgen.htm
Publication date: 2008/01/11 Tags: avr project, microcontroller projects
2X100 Watt Class-T Amplifier Circuit TA2022
The TA2022 is a 90W (4Ω) continuous average per channel Class-T Digital Audio Power Amplifier IC using Tripath’s proprietary Digital Power Processing (DPPTM) technology. ClassT amplifiers offer both the audio fidelity of Class-AB and the power efficiency of ClassD amplifiers. Class-T architecture High Power
AT90S1200 D.D.S. Funktionsgenerator
Das vorgestellte Projekt ist ein Funktionsgenerator für sinusförmige und quadratische Signalproduktion. Die Ausgangsfrequenz deckt den Bereich von 10 Hz bis 100 kHz mit einem Schritt von 2 Hz ab.
Die Wellenformsynthese basiert auf dem D.D.S. Technik (Direct Digital Synthesis) und die Ausgangsfrequenz wird über einen Mikrocomputer mit einer eingebetteten Daumenradtastatur ausgewählt.
