2 Application There pic16f626 application with PWM and LED lasts probably a variety of effects there proteusd the need to try the other simple series-connected LEDs and for limiting resistance is made up of various colors (blue LEDs, green LEDs, white LEDs) LEDs used
PIC12F629 LED neon project
This option LED neon electric site is completely the same as for construction of LED neon, but what is covered is light emitting diode lenses Ice but only so that they are opaque and do not create circles This is carried out zbroušení finest abrasive paper (280 or 1000) under ground water (ustridnete a little square abrasive paper, dip it in water and gently grindstone led diodes – just as 5x probrousit around the lens so that the lens LEDs is not clear but watt = variance light It is very simple. Srdcem je mikrokontroler PIC12F629 (IC2). The heart is a PIC12F629 microcontroller On its inputs GP1-5 are connected to the land of individual buttons (TL1A + TL1B … TL5A + TL5B)
LED backlight car using led neon
I got the idea to try to replace expensive neon (in the order of 4000) LED neon (material to illuminate the whole car will be released under 1000Kc). This variant of neon from the LEDs I’ve ever seen sold in a number of shops, but as far higher price than if you made yourself
Published: 2008/10/05 Tags: led projects, microchip projects, microcontroller projects
12V to 22V IR2184 Coreless DC DC Converter Circuit
12v input voltage of 22 volts dc-dc converter, an inverter circuit that raises the power amp driver stage 5 IR2184, if only on departure made with NE555 integrated MOSFETs BUZ11 2 Fast 2 diodes MBR1645 (16 amp 45 volt)
MOSFETs and diodes are available from most computer ATX power supply circuit power supply 5 volts to 3.3 volts regulated only on departure Getting the MOSFET IRFZ44 usually CEP6030L 40N03 diodes MBR2045 will be those used in the 5-volt output SBL2040
IR2184 DC DC Converter Project
