500W Power Amplifier Circuit Apex B500
| Updated on August 3, 2019
Apex B500 power amp’s pcb design stylish been output mje15032 and mje1503 power transistors used supply voltage symmetrical 55v … 90V from quite high dangerous circuit tests, be careful addition amphitheater to be used with fan control and protection circuit diagrams and PCB drawing is on.
apex-b500-power-amplifier
Source: http://mikrocxema.ru/
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-17448.zip
Publication date: 2011/10/26 Tags: ,
1 Comment “500W Power Amplifier Circuit Apex B500
    8 Channel Opto Triac Driver Circuit
    The driver circuit 220v working with devices or lamps used to control the opto isolators to (moc3020, moc3040 available) provided Signals based on triacs (bt138, bt139 available) transmission is going triac placement of small type cooler made ​​but the power drawn and the working time according to the coolant may not be used already flexible in-circuit power triac triac power varies depending on the way to the cooler part of screwing the middle leg that is associated with that portion when working through the voltage insulators come in contact with the cooler mount
