Motherboard PCI Hack SMD SOIC SOP Adapter
| Updated on June 18, 2014
Computers about a lot of helpful this elektronikd included in the PC power supply of parts a lot of the circuit is done coils, coolers, fans, etc. are used on the main board with materials will work for sure, as long as they need to get on whether considered
Author circuits, SMD for use in programming jobs PCI socket motherboard PCBs cut up into plaques in the plaque with the lock make a nice adapter for SMD SOIC SOP prepared exactly been a DIY do it yourself 🙂
smd-adaptor-soic-aparat-sop-soket-pci-diy-1
smd-adaptor-soic-aparat-sop-soket-pci-diy-2
smd-adaptor-soic-aparat-sop-soket-pci-diy-3
smd-adaptor-soic-aparat-sop-soket-pci-diy-4
Source: chukaev.ru54.com
Publication date: 2011/06/13 Tags:
1 Comment “Motherboard PCI Hack SMD SOIC SOP Adapter
    Led Propeller Circuit AT90S2313 ATINY2313
    Printed circuit board layout pcb design effects with LEDs been a good practice to work in the dark when used with an ultra bright LEDs looks very nice. Atmel AT90S2313 64 LEDs instead of creating Propeller microcontroller TINY2313 BASCOM-AVR 1.11.9.1 prepared with available software sprint pcb layout drawing and drawing spline scheme has the source code.
