Six-Legged Basic Stamp2 Spider Robot Project
| Updated on August 20, 2024
Spider robot mechanically quite a detailed project control system based on pic microcontroller Basic Stamp 2 module is provided with circuit 7.2 Volt NiCad batteries in addition to the fed with the RC5 remote support, there is a variety of sound effects Robot circuit all sources (codes, orcad schema etc) shared a robotic jobs for people dealing with an enlightened project
Spider Robot show
alti-bacakli-orumcek-robot-basic-stamp-2-120x120 basic-stamp-robot-Antenna-120x120 insect-robot-ChassisLow-120x120
orumcek-robotu-robot-devresi-cricket-120x120 robotic-spider-Front_low-120x120 robot-PCB_low-120x120
robot-spider-120x120 robot-top-ust-120x120 robot-yan-mekanik-robotun-saft-120x120
Servo-bocek-robot-motors-120x120 spider-robot-bottom3_sm-120x120
Source: http://home.earthlink.net/~henryarnold/
Publication date: 2011/01/10 Tags: ,
1 Comment “Six-Legged Basic Stamp2 Spider Robot Project
    220V Soldering Iron Temperature Control with AT89C2051 LED Display
    Sold in the market potency heat settings with TRIAC 220v temperature-controlled soldering iron more advanced version control AT89C2051 microcontroller is provided by heat setting 2 button is made with indicators, one for led display used temperature% are read.
    Control circuit with triac driver moc3041 opto-isolated circuit diagram Triac T he G Gheit stated as the cathode and the anode K can use triac BT138. Source C code given to the project.
