Applause Acoustic Lamp Switch Circuit
| Updated on August 3, 2019
Acoustic Switch circuit CD4011 CD4001 Cmos circuits based on supply voltage 12 volts dc according to the sound received through the integrated circuit output depending on cd4001 mikorofon relay works. With the relay contacts in the lamp circuit, the author attached to the running lamp relay is connected to the circuit output that applause. Sound sensitivity can be adjusted with potentiometer P1 100 k on the circuit.
acoustic-switch-lights-contacts-relay-lights-refrigerator-fan
acoustic-switch-12v-relay-anahtari-alkis-lamba-yakma
Source: sokdinantelektronus.blogas.lt/akustinis-jungiklis-137.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19121.zip
Publication date: 2012/06/17 Tags:
1 Comment “Applause Acoustic Lamp Switch Circuit
    Assorted Robot Videos 1
    I have seen videos on youtube I wanted to share an interesting robot designs are really good so far, but people did not leave any robot application gives As I watched the enthusiasm
    Robots: Arduino Powered TreeClimbing Robot, Directional Insect Robot, Farming Prospero Robot, Quadruped Robot, Morp Hex robot
