Active Subwoofer Amplifier Circuit TDA7294 VU Meter DC to DC Converters
| Updated on August 3, 2019
Active subwoofer amp designed for use in the car cabin floor TDA7294 2SC5200 and 2SA1943 used, but the addition of an integrated output power to the output of this circuit is upgraded patlaşıl previously had different PCB drawing ; TDA7294 Power Transistor Output Power Enhancement Supplements
TDA 7294 2x38v DC symmetrical supply is working with cars for use in the TL494 PWM control integrated on the board dcdc converter circuit made ​​additional olrak active bass filter and vu meter circuit well made subwoofer cabinet handmade original from a drawing made ​​already all circuits inside the cabin is mounted
dcdc converter circuit for use in a car is a must but if you use the integrated amp 12v working with do not need or want to use it at home can be operated with normal transformer and rectifier circuit
VU Meter with LM3915 in the TDA7294 amp , TL494 and bass dcdc converter control circuit diagram of PCBs and PCB drawings have cabin dimensional drawing program can open files sprint layout
active-subwoofer-tda7294-bass-filter-kabin-oto-amp
anfi-devresi-tda7294-vumetre-devresi-woofer-devresi
tl494-dcdc-smps-pwm-car-power
car-bass-speaker-box-araba-sub-kabin
source: cxem.net/sound/dinamics/dinamic92.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21244.zip
Publication date: 2013/03/16 Tags: , , , ,
2 Comments “Active Subwoofer Amplifier Circuit TDA7294 VU Meter DC to DC Converters
    Isolated USB Adapters RS232 RS485
    There are 3 USB converter circuits CP2102 USB communication as in the isolation section of the ISO7221 standard is being used. USB/RS232 adapters isolated TTL (RX-TX), isolated USB/RS485 adapter (+ max13488) usb1wir isolated adapter (+ DS280)
    Aktiv-Subwoofer-Verstärker Schaltung TDA7294 VU-Meter DC-DC-Wandler
    Aktive Subwoofer-Verstärker für den Einsatz in der Kabine Kabinenboden TDA7294 2SC5200 und 2SA1943 verwendet, aber die Zugabe von einer integrierten Ausgangsleistung an den Ausgang dieser Schaltung wurde aktualisiert patlaşıl hatte zuvor verschiedene PCB Zeichnung; TDA7294 Leistungstransistor-Leistungsverstärkung ergänzt
    TDA 7294 2x38v DC symmetrische Versorgung arbeitet mit Autos für den Einsatz in der TL494 PWM-Steuerung integriert auf der Platine dcdc Wandlerschaltung gemacht zusätzliche olrak aktiven Bassfilter und Vu-Meter-Schaltung gut gemacht Subwoofer-Kabinett handgefertigtes Original aus einer Zeichnung bereits alle gemacht Schaltungen in der Kabine ist montiert
    dcdc Umsetzer Schaltung für den Einsatz in einem Auto ist ein Muss, aber wenn Sie den integrierten Verstärker 12v arbeiten mit nicht brauchen oder zu Hause verwenden, kann mit normalen Transformator und Gleichrichterschaltung betrieben werden
