8051 Development Test Circuit 8051 Example Code
| Updated on August 5, 2024
8051 microcontroller is a useful post for programs designed to try the circuit. As a Test circuit has rs232 serial port the display, compress, ISP, IC2 (AT24C02), eeporom, led, pushbutton, IR receiver parts.
In addition to the RS232 serial port test circuit’s display buzzer ISP IC2 (AT24C02) eeporo button, IR receiver section I have led. Protel prepared by the printed circuit board, bill of materials and schema files are
8051 Development Board
8051-mcu-development-board-sch
Source: www.zsmcu.com Download 8051 Development Example Code files:
Publication date: 2010/11/13 Tags:
1 Comment “8051 Development Test Circuit 8051 Example Code
    Atmel application notes and source c asm code
    Atmel’s products and practices related to application notes prepared for the asm code source c c language prepared by the majority of the samples. 138’s application
    List:
    1-Register and Bit-Name Definitions for the AVR Microcontrollers
    2-Accessing the eeprom
    3-Block Copy Routines
    4-Setup and Use the Analog Comparator
    5-Multiply and Divide Routines
    6-16-bit Arithmetics
    7-BCD Arithmetics
    8-Bubble Sort
