The driver circuit 220v working with devices or lamps used to control the opto isolators to (moc3020, moc3040 available) provided Signals based on triacs (bt138, bt139 available) transmission is going triac placement of small type cooler made but the power drawn and the working time according to the coolant may not be used already flexible in-circuit power triac triac power varies depending on the way to the cooler part of screwing the middle leg that is associated with that portion when working through the voltage insulators come in contact with the cooler mount
Driver circuit pcb, schema eagle files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19763.zip
Publication date: 2011/10/15 Tags: analog circuits projects
SMPS PWM Proteus isis Library Models
AC to DC dc to dc are popular used in many applications in power electronics, old, new SMPS, PWM control driver proteus isis models of integrated and library files …
Some models also for the next test in the circuit’s simulation isis.
