Circuit 74ls164 8-Bit Serial Input Parallel Out Shift Register entgre idols are a fine example of the work. When the rising edge of the clock input signal is applied to the input signal from the ugulanan each colck pulse is shifted to the right. When the continuous clock pulses applied enteree wherein opening and closing switch circuit operation can be observed.
74LS164 Circuit Example schematic
Working example of the shift register 74LS164 Proteus simulation file:
74LS164 Example Shift Register Circuit
Publication date: 2010/11/18 Tags: analog circuits projects, simple circuit projects
PIC18F4550 PIC18F2550 USB Project VisualBasic Circuit
There are approximately 200 USB control software applications are generally prepared with the Visual Basic used PIC18F2550 microcontrollers, the PIC18F4550 codes written in C language. USB ADCs, etc. USB hidden. circuit has a lot of programs.
USB Project example schematic
