BCD Counter 74LS160 Serial Connection Example Circuit
| Updated on August 5, 2024
A design of serial connection to the instance of the circuit 74ls160. This can be done by connecting to the desired number, counting up the şekildeö integrated serial. 2 entgre count can be done with 99. 5 integrated with the number 99 999 a removable. 74ls160 integrated circuit oscillator circuit with number 2 connecting the output CLK pin 555 circuit frequency according to the substitution can be made.
74LS160 Example Circuit Serial Connection schematic
74ls160-sayici-counter-circuits-devresi-74ls160-seri-serial
74LS160 serial connection of the isis circuit simulation, for example:
Publication date: 2010/11/18 Tags: ,
1 Comment “BCD Counter 74LS160 Serial Connection Example Circuit
    74LS164 Example Shift Register Circuit
    Circuit 74ls164 8-Bit Serial Input Parallel Out Shift Register entgre idols are a fine example of the work. When the rising edge of the clock input signal is applied to the input signal from the ugulanan each colck pulse is shifted to the right. When the continuous clock pulses applied enteree wherein opening and closing switch circuit operation can be observed.
    74LS164 Circuit Example schematic
