3 Bit Counter Circuit TTL 7447 74160 NE555
| August 5, 2024 Updated
74160 7447 3 bit counter designed with integrated tll. For each bit, 1 display, to drive displace 74,160 in 7447 and counting is used. 74 160 s 3-bit counter formed by connecting serial number of 74160 can be increased by increasing the number of bits.
Circuit NE555 square wave oscillator circuit to provide clock pulses and 50 Hz oscillator source used with the 4052. By pressing the START button 555 out of outputs HIGH level for a certain time. X1 output from 555 in 4052 to the “1” with the knowledge of the information in 50hz oscillator to give a total. X1 by taking exit 50 Hz signal that will be applied on the circuit in the output circuit 555 is “0” will continue until the counting.
Counter Circuit Schematic
sayici-devre-isis-proteus
Counter Circuit proteus isis circuit files:
Published: 2010/11/28 Tags: ,
1 Comment “3 Bit Counter Circuit TTL 7447 74160 NE555
    Stereo 100W Amplifier Circuit PAS4100 Prologic Shikhman
    BJT transistor circuit description of a quality amp circuit diagram pcb’s drawings. Prepared persons (author unknown a circuit in the archive) thanks the following descriptions are his own.
    Drive transistors. BC548C instead of 2SC3198 (BC237), instead of 2SA1266 BC558C (BC307C) can use. Output transistors from low to high, depending on the supply voltage TIP3055-TIP2955, BD911-BD912,-2SB688 2SD718, 2SC5200-2SA1943, BD249C-BD250C be used as a conjugate. Circuit of the original supply voltage + / – 35V CAR POWER AMP and PAS-4100. 2 channel has been designed by me.
