600W Class D amplifier Ir2110 (4 ohm 8 ohm 1000W)
| Updated on August 4, 2019
Class D amplifier circuits switch mode switched work thanks so much less material with higher power can give. 600w high power 2 provided with circuit bridge connection (4 ohm speakers with 1000w) for a total of 4 PCs FDP2532 mosfet is used (instead of IRFP250) mosfet driver circuits is controlled with the Ir2110 MOSFETs. Class D amplifier circuit used coils 30uh worth Ei33 core wrap tie wire 0.4 mm 7 pieces parallel the author 14 tour either said
NE555 timer IC against excessive current draw on the amplifier Board protection circuit-65v supply line connected to the serial 0.05 Ohm 4w voltage across the resistor resistor according to Ir2110 entegrelerini took the sleep mode. 600w Class D amplifier project pcb and schema drawings.
class-d-amplifier-circuit-class-d-anfi-class-d-amplifier-ir2110-1000w-600w
class-d-szuro-utan-tile
ATTENTION 600W Class D amplifier circuit is working with high voltage to + 65v-65 total 130v careful capacitor connections, make sure you connect the opposite poles of high voltage + can be large explosions – the insured before you run the circuit power line, use protective eyewear
source: hobbielektronika.hu/cikkek/600w-os_d_osztalyu_vegfok.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22294.zip
Publication date: 2013/11/09 Tags: , , ,
2 Comments “600W Class D amplifier Ir2110 (4 ohm 8 ohm 1000W)
    Mosfet Isolated RGB Led Driver Module
    Microcontroller or different control integrated with high-power RGB LEDs rides designed for RGB LED driver circuit difference from others PC817 Optocoupler controlled by solid drive solid isolated from .. In some applications it between two layers of insulation may be required. RGB LED Driver circuits IRFZ48 MOSFETs used in the sprint circuit pcb layout drawings prepared by the source’s small in size and placement of SMD type design made ​​good
    1000W Klasse-D Verstärker mit Ir2110
    Klasse-D-Verstärker schaltungen Schaltermodus geschaltet arbeiten Dank so viel weniger material mit höherer Leistung geben kann. 600w high power 2 mit Schaltung Brückenschaltung (4-ohm-Lautsprecher mit 1000w) für insgesamt 4-PCs FDP2532 mosfet verwendet wird (anstatt IRFP250) mosfet-Treiber-schaltungen gesteuert wird mit den Ir2110 MOSFET. Klasse-D-Verstärker-Schaltung
