8Ω + / – 35V – 40W sinus plate amplifier power. Jeden kanal. One channel. The layout is based on symmetrical arrangement of input from current and balanced agreement, control Contains DC Servo system for the precise determination of zero output. The degree of current contains transistors bipolarne. It voltage to + /-24V and + /-39V. Of course, when other elements of other possible supply voltage.
Sine Wave Amplifier Circuit
Sine Wave Output MOSFET 40W Amplifier Circuit
Published: 2008/08/28 Tags: audio amplifier circuits, transistor amplifier
ARM7 LPC2138 Universal Control Board
The Single-chip 16/32-bit microcontroller LPC2138 is an ARM7 microcontroller from NXP in a 64pin housing a wealth of peripherals, and myself as a basis for control projects. The board is described in an area of 100mm x 75mm functions
