350 Watt Studio Amplifier Circuit MJL21193 MJL21194
| Updated on July 2, 2023
Quite strong quality studio symmetrical amplifier circuit supply voltage + – 2×70 total of 140 volts dc volts DC Volts high voltage, be careful.
Of the amplifier to the power supply 500 Watt 2 × 50-volt transformer see your work output transistors for the 4 × 4 MJL21194 and MJL21193 used prices can be high, but for this work have been produced quite powerful transistors also this power amp for your circuit output protection circuit would recommend The circuit will have to do . Circuit 8-ohm speakers with 4-ohm speakers with 200w 350w is powering.
350w-amp-power-amplifier-circuit-rms-anfi-devresi-amplifier-studyo-anfi
The power supply used in the scheme is 6 8000uf kullansat 10000uF can use this value instead of a little hard to find. If the bridge diodes to be used should be 35 amps metal type power transistors used for cooling as in the picture large honeycomb cooling fan for better cooling, and even, I would suggest you to connect
PCB quite stylish in design and clearly amp circuit diagram also contains voltage information in critical areas in the test, trial operations will work for you.
350 Watt Studio Amplifier Circuit files :
Publication date: 2008/01/12 Tags: ,
2 Comments “350 Watt Studio Amplifier Circuit MJL21193 MJL21194
    Super Electronic Calculator Program MiscEl
    Geometry, air water-related calculations% RH, periodic, light calculations, charge, discharge, Ohm’s Law, resistor circuits 555 timer integrated including the simple circuit for charge / discharge time calculator, mechanical, unique and a lot more feature
    “Miscel” Super Electronic Account program is able to calculate Electronics also a lot about a free program
    350 Watt Studio-Verstärkerschaltung MJL21193 MJL21194
    Sehr starke Qualität Studio symmetrische Verstärkerschaltung Versorgungsspannung + – 2 × 70 insgesamt 140 Volt Gleichspannung Gleichspannung Hochspannung, seien Sie vorsichtig.
    Vom Verstärker zum Netzteil 500 Watt 2 × 50-Volt-Transformator sehen Ihre Arbeitsausgangstransistoren für die 4 × 4 MJL21194 und MJL21193 Gebrauchtpreise hoch aus, aber für diese Arbeit wurden auch diese Endstufen für Ihre recht leistungsfähigen Transistoren hergestellt Schaltung Ausgangsschutzschaltung würde empfehlen Die Schaltung muss tun. Circuit 8-Ohm-Lautsprecher mit 4-Ohm-Lautsprechern mit 200 W und 350 W werden mit Strom versorgt.
    Das im Schema verwendete Netzteil ist 6 8000uf kullansat 10000uF kann diesen Wert anstelle eines etwas schwer zu findenden verwenden. Wenn die zu verwendenden Brückendioden Metall-Leistungstransistoren mit 35 A sein sollten, die zur Kühlung verwendet werden, wie im Bild gezeigt, sollte ein großer Wabenkühlventilator für eine bessere Kühlung verwendet werden, und ich würde Ihnen sogar den Anschluss empfehlen
    Die Platine ist sehr elegant im Design und der übersichtliche Amp-Schaltplan enthält auch Spannungsinformationen in kritischen Bereichen des Tests. Der Testbetrieb funktioniert für Sie.
